Proper viscosity for '08 Vibe?
Originally Posted By: mikered30
I never understood why the TSB applies to the 06 and 07 1zz fe. I know the 05+ have a longer dipstick, hence can hold more oil. Is that the only difference? If so, why doesn't the 05 apply?
05 does have the longer dipstick and holds less oil than the 06 and later 1ZZFE motors.
(I've always wondered if I could get an extra 1/2 quart in the motor but since all is good, why bother?)
According to what I've read on the internet, Toyota did change a few things in 06 (but if only because of 5w-20?)
I'm sticking with 5w30 in my Corolla. It works well and MPG is good enough for me.
Originally Posted By: pbm
Would 2 quarts of Pennzoil 5w20 conventional and 2 quarts of Pennzoil Conventional equal 4 quarts of Pennzoil Conventional 5w25? Would there be any additive clash? This sounds like a good compromise for this engine.
It would work well. I DOUBT if there would be ANY problem with "additive clash".
Bill
Originally Posted By: Saturn_Fan
I have a 2008 Corolla with the same 1ZZFE engine the OP has. Mine says 5w30 on the oil cap. TSB has no mention of 2008 1ZZFE engines and I called several dealers.
The dealers I called told me that my 2008 1ZZFE should be running 5w30 and strongly made it clear that the TSB wasn't applicable to me and for warranty purposes I had better be running 5w30.
Then by all means run 5W30. I read about TSB's which I thought applied to my 08 Jeep. I called 3 dealers and asked the same question and got the same answer three times. The TSB's didn't apply to my vin #. Before I go changing oil grades I'd be certain the TSB applied to my car, especially if I dug it up on the Internet.
