Originally Posted By: Vibe_2007
Realize winter is a long way off, but I like to think ahead a bit.
2007 Vibe with 127K. Fed a steady diet of 5w30 since purchased.
Toyota TSB says 5w-20 is okay in the 1ZZ-FE in my model year.
Car has never used a drop of oil on 5w30.
Last winter there were temps many times of -22F, -10F, etc. and the car doesn't have a block heater and at this time in the car's life I don't want to purchase and install one. The wife is going to start taking this car over full-time and thought the 20wt oil would warm up faster for her in the mornings.
Do you guys think 5w-20 this late in the car's life would cause some oil usage or excessive engine noise?
If not, what is considered the best extreme cold 5w-20 out there? I use the QSUD the past couple winters in 30wt.
The TSB does mention not going to 0w-20, so that isn't an option, only 5w-20.
actually, the toyota block heater for the 1zzfe is rather simple to install.
no plumbing work needed. been trying to dig through genvibe for the part #... but it's only like $40, basically a little metallic nub that threads into a hole on the "back" side of the block (Diver's side of car, under the air cleaner)
You're right. You don't even have to drain coolant. Looks like a small cylindrical void in the engine block and it snaps in. The price I've seen online is 65.99.
found this aftermarket piece(Kat's) on amazon:
Amazon.com: Kat's 11813 Engine Heater Cartrige $38.47 + $7.77 shipping (not Prime Eligible)= $46.24
