Proper Synthetic for 2002 GTI 1.8 Turbo
I just switched my '99 Saab turbo from M1 0W-40 to the new M1 5W-40 (yellow cap). Winters typically go as low as 0°F & summer as high as 100°F, & I run the same oil for the full year. I think this is a better application for turbos, as the High Temp/High Shear rating is a bit better.
Is the M1 5w-40 (assuming that's not Delvac) a Group IV or V based? I'd rather keep it wholly (or as whole as possible) synthetic. I cant' say I've ever seen this 5w40?
Hrmm, I see this is a Truck/SUV oil. Marketing Gimmick?
[ May 19, 2004, 02:40 PM: Message edited by: Mindflux ]
Well I called around everywhere looking for the 5w40 T&SUV M1. Advanced didnt have it, autozone didn't. Wal-Mart said they didn't. But knowing these jokers, they didn't bother checking. I drove down to Wal-Mart and saw it on the shelf. Didn't buy it yet though, I'm a bit concerned that my dealer (VW) may flip out if they see it says Truck&SUV.
quote:
Originally posted by sprintman:
RL 5W40. Tyrolkids UOA's are hard to beat. Amsoil 20W50 has a lot of users and great reputation here in Oz.
The problem is I can't get 5w40 locally. Perhaps I can order direct from RL....
Mindflux:
Why not just stay with the M1 0w-40?
I think you're looking for an answer to a problem that you don't have.
Darryl
quote:
Originally posted by Mindflux:
quote:
Originally posted by harrydog:
alternatives.
-Ryan
If you have any Advance Auto Parts stores in your area, you should be able to buy Redline 10w40 off the shelf. I've had very good UOA results with it in my Subaru turbo.
Thanks! I had called them last night and they said they had 5w30 and 10w30, but no 10w40 or 5w40. I asked if they could order it and they said no.
That's too bad. I guess each store orders what they want. Frankly, I wouldn't hesitate to use Redline 10w30. It will protect much better than a conventional 10w40 or 5w40, which is probably what VW has in mind when they specify the oil for their cars.
Also, I usually order my Redline from myoilshop.com (a sponser here). They have good prices.
alternatives.
-Ryan
Unfortunately they don't carry 5w40 either
We'll see, I've still got about 1k of driving before I need to change out my M1.
Mindflux, I see you live in Texas. I would be using the 10w40 rather than the 5w40. The 10wXX synthetic oil will flow at least as well as a 5wXX conventional oil at cold start-up and might give you a bit more high temp protection. I've heard that VW engines run a little on the hot side anyway. That, plus performance mods, plus a warm climate...I see no reason for a 5wXX oil.
But that's just me!
I've using the Amsoil 10w-40, 10w-30 and now Series 2000, 0w-30 in my 2002 Audi TT roadster which has the 225 Hp version of this engine. All of them worked just fine, in fact if you do a search I posted results for the 10w-40 and 10w-30.
If you can get the Amsoil 10w-40 locally, I'd simply use that. The Amsoil 5w-40 and 10w-40 use a very similar basestock blend and my oil analysis testing shows they use a similar additive chemistry as well. I'd consider these two formulations to be basically interchangable ....
To be honest, the main reasons why Amsoil came out with a 5w-40 is that some owners of high end, European vehicles are totally "AR" about sticking with the exact manufacturers viscosity recommendation. You can actually run anything from a 0w-30 to a 10w-60 in this engine, mainly depending on the lowest starting temps you are likely to see.
Up until about 1999, VW/Audi published a very comprehensive oil viscosity/temp chart for their engines that allowed numerous SAE grades to be used. Their 5w-30/5w-40 recommendation is merely a "dumbed down" version of that chart. The logic is that 5w-30/5w-40 are good compromise viscosities that can be used throughout the year, anywhere in North America. So there is a slight perference for 5w-30 over 10w-30, and 5w-40 over 10w-40 if you live in an extremely cold place.
Tooslick
www.lubedealer.com/dixie_synthetics
I agree with others that you are looking for the answer to a problem that doesn't exist. Stick with the M1 0w-40, no need to mail order, and it is easily found.
If you have to try another oil, either the Redline 5w-40 (which seems to really mate well with the 1.8t) or Amsoil are great choices. I personally prefer Redline, but it is like saying that prefer BMW to Mercedes.
I'll PM one of the AMS guys here and see what they say.
This place is great, however.. (like every other walk of life) it seems there are some "haters" of each brand.. it's so hard to chose!
I wouldn't call them haters......just very "passionate"
