Proper method to change your brake fluid?
Originally Posted By: Yup
Originally Posted By: Ducked
Originally Posted By: HTSS_TR
For the ones who had concern about air bubble goes around the bleed screw back into the brake system, will you explain how air can go opposite direction of brake fluid which is sucked out of the brake system into a vacuum reservoir ?
That's probably not a significant risk, but if you're trying to remove air from the system by sucking it out, (as when refilling a drained system) the bubbles make it impossible to tell if/when you've succeeded.
Blowing works better for that, though there is allegedly a risk of everting seals in the master cylinder, and there's a real risk of pushing muck into it.
I've used as much pressure as I can generate with a syringe, which creates a noticable upwelling and turbulence in the master cylinder, and so far havn't experienced the first problem.
I cycle maybe 20 mls of fluid in-out a few times first to stir up and remove muck in the calipers/wheel cylinders/piping.
There are so many posts I could make right now that people would laugh over.
Oooo....SCARY!
You mean...he said "suck" stylee? Its been done.
With irony.
