- Joined
- Aug 3, 2024
- Messages
- 268
I have the above truck (since new) and live in a humid environment, because of this I like to do a brake fluid flush on all my vehicles every few years. I've done this plenty of times before but this will be a first on my Silverado. I've done all the internet research but the info is quite inconsistent, some say it's just a simple bleed like any other brake system (as long as no air gets introduced), while others claim the the ABS has to be cycled with a diagnostic scanner among several other additional steps. I understand this is necessary if a component is replaced and air gets in the system upstream of the ABS module, but is all that required for a simple fluid exchange?
I have both a Motive pressure bleeder and a basic vacuum type, I'll likely use the Motive if I can get a proper adapter. I also have an XTOOL Anyscan A30D Bidirectional Scan Tool that I'm pretty sure will activate the ABS module (it did on my Nissan Frontier), but I'd like to avoid that if necessary.
Thanks as always for any input.
