I purchased a Scooter (2009 Yamaha Zuma 125) to commute on about 6 months ago and in that time I’ve put about 2,000 miles on it and gone through all the maintenance items I can think of except for checking the valves. Recently, we had a 110 degree day which I got caught up in riding home from work in and ever since the scooter has been making some strange noises. So last night I went to change the oil and adjust the valves and I found a good amount of metal in the Oil strainer (thanks Yamaha) and the lower exhaust valve cover. Now the previous owner must have short tripped the heck out of the bike because I found some internal rust in the PCV Breather connector which I hastily cleared out best I could but this rust may have gotten cleaned out during my more routine oil changes and dumped into the engine.
Anyhow, after the valve adjustment and service its still not sounding good so, my purpose for this thread is to prolong the inevitable. Its not worth pumping a ton of money into but I would like any suggestions for prolonging the engine life. Although it is a commuter scooter it does get hot and up to temperature by the time I reach work daily. Should I keep using Synthetic 10w-40 and just ride it until it dies/ monitor the metal particles?
The Oil specs: 10w-40
Thank you all.
Thank you all.
