Originally Posted By: azsynthetic
You're going to need a couple of spare tires and tools to change it out with. Get a smaller mirror to cut down on the road noise and drag. Replace the headlight bulb with a higher wattage one for night driving. If you hit a pot hole with those small tires you are going to flip.
Installing and balancing a tubeless tire is a bit beyond my means. I think I'll stick with a patch kit, and be ready to abandon the attempt if I hit a nail and the hole won't stay patched.
The bike's limited electrical system is likely to limit any increase in headlight brightness. The stock light is plenty bright, particularly with the high-beams. The chase car's headlights reach even further, and they won't be far behind.
The tires are indeed small, and avoiding potholes is important, but I've been lucky to avoid any major potholes -- the wheels seem to glide over the smaller ones with only a bit of jarring
Originally Posted By: dsmith41
I'd put some 15w40 Rotella in it and ride. When do you plan on doing the ride? I hope to do a SS1000 next summer on my Shadow 750. You better make sure JimVegas isn't correct about them not certifying unless you have a 250cc or bigger. Even though you would know you did it, it would suck if they wouldn't accept your ride.
How do you like the Shadow? I've been thinking of eventually getting a "real" motorcycle, particularly for daily commuting, fun, and general transportation. The Shadow's been near the top of my list.
