Cannot find conventional 75w90 gl4 gear oil. Any suggestions?
80w is allot thicker, so trying to find the 75w. Thanks
Same stuff
I am topping off a differential that has conventional in itWhy does it need to be conventional? Synthetic isn't more slippery and problematic regarding the blocker rings/synchros if that's your concern.
Torco 75w90 is syntheticTorco rgo 75 w90 order it on Amazon
What vehicle or machinery is this?I am topping off a differential that has conventional in it
Yep, you'll get gear clash. Dedicated standard tranny lubes have chemistry that's designed for synchronized trannies. Redline MT-90 for the win!!I do realize the need for GL4 in a manual transmission as GL5 gear oils are too slippery for fast gear changes. Even the yellow metal safe GL5 gear oils suck in a manual.
You're too hung up on the numbers VS. how those numbers relate to performance. Like has been mentioned already - 80w90 is what you need. Or 75w90 synthetic works as well or better, and is fully compatible with any conventional.80w is allot thicker, so trying to find the 75w. Thanks
