Ok so I'm doing it. I'm going to ask the question that has been on my mind for a while. I will even predict the answer to be "just run 5w40 year round, you'll be fine" but that won't actually be the answer to the question I am going to ask.
I recently purchased a 2016 Nissan Titan XD with the Cummins diesel in it. While reading the owners manual (we all RTFM right?) I noticed that for all temperatures above -10F the recommended oil is 10w30 CJ-4. For temperatures below -10F up to 68F they recommend a 5w40 for easier starting, etc.
Now to the question...(no it isn't what oil should I use but if you want to include that in your answer go for it)...Why? Why would a manufacturer recommend 10w30 for all temperatures above -10F and yet limit the heavier, thicker, oil to a max temperature of 68F? I'm sure I would be fine running 5w40 all year, but I am that sort of person that tries to understand things and the reasoning behind them and I just can't wrap my head around it.
My closest servicing dealership is over 100 miles away. I gave them a call, and the 1st thing they told me is they won't work on them because there isn't the demand and they don't have a diesel tech. Then the service guy went and talked to the tech and came back with the generic "follow the owners manual" answer.
Again, I'm not really looking for a recommendation of weight, brand, etc., more looking to understand the reasoning behind the recommendation as published by Nissan/Cummins.
Thanks,
~Travis
PS - I should add that this is my first diesel so I'm still learning in that regards so I will appreciate recommendations even if it isn't what I'm ultimately asking.
Thanks,
~Travis
