- Joined
- Aug 9, 2022
- Messages
- 170
Hello All,
I am looking at purchasing a charger for a Costco Interstate 730 CCA H6 (48) size flooded lead acid battery with a 70AH capacity, although I am having a hard time determining the correct maximum charging rate and charger size (Interstate doesn't appear to publish data sheets with this information, and their customer service was no help). Some online sources I have read state that this size battery should be charged at .1C (7 amps), others at .2-.25C (14-17.5 amps), and others say anything below .3C (21 amps) is acceptable.
I like the Pro Logix chargers best for the great reviews and the good features at the price point including the multi-select charge rate, ability to charge from 0 volts, "exercise mode" maintainer, power supply mode. The Pro Logix PL2320 has a 20 amp "fast" charge setting which would allow full charging in 3.5 hours, and it would be nice to be able to use the vehicle in the same day if you come out to find a completely flat battery.
Would it be safe to charge this battery at 20 amps without harming the battery life, or otherwise detrimentally affecting the battery? The standard charge rate on the PL2320 is 10 amp, which is also higher than the lowest charge rate of 7 amps (.1C) I came across. Would I be better off to go with the PL2310 which has a 6 amp standard charge rate that is closest to the .1C charge rate, or would it be ok to go with the PL2320 with the 10 amp standard and 20 amp fast charge rate?
