That's a good point. I've had 4 different vehicles (only one was mine) blow up a brake line. It always happened when the vehicle was getting to be 10 - 12 years old. It's easy to spot bad brake hoses as they'll have very fine cracks in them or they'll be "sweating" brake fluid. I saw this on a fire truck once... The metal lines are tricky, I suppose the rule of thumb should be to replace them if the ends are difficult to undo. I removed two sets of 20+ year old brake lines on my motorcycles, they were in great shape but nothing like good old stainless braided lines.
Here's some more:
Packing wheel bearings is a necessity on some vehicles.
Doing an alignment with each set of tires can't hurt.
Undercoating every year is mandatory up here.
Looking for heat damaged wiring connections will prevent break downs.
Putting air in your spare tire will pay off if you ever need to use it.
Put anti-sieze on any bolt that you remove while working on the car.
Getting your distributor timed is good, even on EFIs.
Change your rear seal and transmission seals when you do the clutch.
Get your diesel injectors rebuilt every so often (I don't know when, but it helps when done on bad ones)
Clean out any vents on the diffs and transmissions during a service or they'll pop the new seals.
Change the shocks and springs every so often.
Get the body polished and waxed yearly, shampoo interior.
If you can get to it check to see if the EGR can move.
Use parking brake daily to prevent seizing.
Adjust valves as per manual.
Stare at your car for an hour a week, you'll notice something.
Cheers, Steve
