Congratulations on your 1st BB. NASSAU is far and away the best of the T3 BB's. Guns are a little small( 283MM as I recall )but overall it is the best of them no question. I knew you were going for the KM BB's as fast as you could.
How are you doing so far on aiming with it? Got many Citadel hits yet? Make sure when you are aiming at the side of an enemy BB or CL( pretty much straight on or just very slightly angled )that you place the target line pretty much right even with where the water meets the hull( or just up a hair ). This will give the most Citadel hits if you lead right. The exception really being higher tier German BB's that are almost impossible to Citadel so you line up on the area where the hull meets the deck or just a hair below it.
Do it right on a CL and get a couple Citadels hits and you can take out a full HP one with a single salvo. Nothing more awesome that to see that full HP ship just go POOF! Especially when you do it at max range. Furthest I have done a Devastating Strike( what they call it in game - ship must have at least 50% of it's HP to qualify )to this point is at a little over 17km. Took out a T5 OMAHA that was full strength. Got 3 Citadels and it just vanished. I was like
Not quite as easy to do early on as the guns are really inaccurate at T3 for all BB but it gets better as you rise.
Congrat's again.
PS - what name are you using when you play? I might see you in a game when using my T4 WYOMING.
Congrat's again.
