anyone know if prestone brake fluid have harsh chemicals in it? i've noticed that there is a of black dirt accumulating at the bottom of the clutch reservoir which i assume is from the rubber clutch hose lines.
Prior to prestone, i was using Honda oem brake fluid. No signs of black dirt and the fluid would be amber.
Reservoir-clutch fluid bled 9k miles ago. The fluid is actually clean, its just that dirt accumulated at the bottom.
cleanliness of fluid-just dipped toilet paper in there
dirtiness at the bottom-swiped the bottom of the reservoir with the toilet paper.
thoughts?
thoughts?
