My friend has inherited an old 190SL that has sat in a garage undriven for 5 or so years.
She indicated it had some brake issues (perhaps a stuck rear drum shoe, so I took a look.
First thing I noticed was that the brake fluid reservoir was bone dry, with just some oily bluish/black residue in the bottom. The service manual from that era recommends only ATE and "Lockheed-equivalent" brake fluid.
A few questions for you:
1) Has anyone experienced this ATE residue situation? I do know it is blue vs. the normal clear/amber DOT-3 fluid from Prestone
2) Is DOT-3 fluid compatible with old ATE fluid? She did put some DOT-3 Prestone in the reservoir and seems to be
3) Oddly enough, the pedal is quite firm -- no sponginess that you'd see with air bubbles in the lines.
4) No obvious leaks in the lines or master cylinder when inspecting.
Thanks for your input!
