ATE Super DOT 5.1 Brake Fluid
Idaho
Continental has expanded its portfolio of ATE brake fluids for the automotive aftermarket with its new OE quality ATE Super DOT 5.1.
“More and more carmakers are specifying DOT 5.1 for their vehicles, and we want to make sure that this new manufacturer-recommended brake fluid is readily available as a replacement fluid for our aftermarket customers in the U.S. and Canada,” said Dan Caciolo, head of product management for engine management & brake systems.
Continental says ATE Super DOT 5.1 premium brake fluid combines a high wet boiling point of 356°F and good viscosity at very low temperatures. With a maximum of 750 mm²/sec. at -40 °F, ATE Super DOT 5.1 viscosity values exceed even those of ISO Class 6, which the company says are well above the specifications for DOT 5.1 class brake fluids.
ATE Super DOT 5.1 is a glycol ether-based brake fluid and must never be mixed with silicone-based DOT 5 class brake fluids.
Colorado Springs
ATE is always safe bet, but will never get over their blue stuff. Two days ago I was flushing BMW with TYP200 and thinking how convenient blue stuff was.
Vancouver, Canada
I just keep on using Bosch ESI6-32N Brake Fluid which has 365F wet boiling point and I bet it's cheaper too. Very happy with that brake fluid.
