Low Viscosity Brake Fluid
Metro Vancouver
I'm looking at brake fluid because my car is due for a flush. I will be replacing ATE Super Blue with something else, possibly ATE Type 200. While looking at the various specifications, I noticed that there are low viscosity DOT 4 fluids, in addition to regular DOT 4 fluids as well as DOT 5.1 fluids which I understand are all low viscosity. I was initially going to go with ATE Type 200 because it has the same specifications as Super Blue, but now I'm not sure whether to go with DOT 4, DOT 4 low viscosity or DOT 5.1. Since low viscosity brake fluids are relatively recent, are there any issues or trade-offs using them in older vehicles, such as my 2002 M3? According to the manufacturers such as ATE, Pentosin and Motul, apparently not, but I thought I'd ask about this here, since there hasn't been much discussion about brake fluid.
Nope, no tradeoffs at all, and low-visc brake fluids are totally backwards-compatible with regular brake fluid.
In fact, the low-visc fluid will actually make your ABS work better
Wagner Severe Duty DOT 5.1 is my brake fluid of choice. Other good options are Castrol DOT 4 (viscosity not as low as DOT 5.1, but lower than most brake fluids) and Pentosin LV.
If you flush brake fluid frequently and/or have a lot of cars, the Castrol stuff is cheap in bulk on Amazon. There is also Ravenol DOT 5.1 on eBay at $45 for six 1L cans.
All the cars in your sig will love low-visc brake fluid. Use it with confidence in any car that calls for DOT 3, 4, or 5.1
I've been using ATE SL.6 low viscosity fluid in my 2005 Subaru for the last 4 years. No problems with it.
Compared to the Type200 and SuperBlue, boiling point is a little lower, and change interval is 2 years instead of 3 years
I have used it in a 2005 Jeep Grand Cherokee, 2010 Mitsubishi Lancer, and 2011 Honda CRV. All cars call for DOT3, but I am using Pentosin DOT4LV.
I haven't had a problem in any car.
So - my car has a DOT 4 - LV spec recommended WSS-M6C65- A2 / ISO 4925 class 6 low viscosity. I assume Dot 5.1 works fine for this spec?
thanks
-srs
2014 Ford Fiesta 1.5 TDCI (Mobil F1 5w30 A5/B5 Ford WSS-M2C-913D) | 2014 Mahindra Scorpio 2.2 mHawk (Amsoil CK4 Turbo Truck)
thanks
-srs
Correct. DOT 5.1 will work fine
thanks
-srs
I would not be so sure about this.
DOT 5.1 fluids have a max spec of 900 cST at -40C, DOT 4LV requires 700 cST at -40C, max.
https://www.bremboparts.com/america/en/products/hydraulics/brake-fluid
So, while it is possible for a DOT5.1 fluid to meet the low temperature requirements for a DOT4LV, this cannot be assumed.
thanks
-srs
No, it will not. DOT 5.1 does not meet the low temperature requirements of DOT4-LV.
Yes, it does.
The max visc for 5.1 is 900 mm/s**2
I'm not in a location where the temperature hits -40 C. +40 sure, thats a relatively mild summer out here in the tropics.
The reason for my asking all this is that the nearest Ford dealers are at least a hour and a half from my apartment after one of their dealers nearer my place went out of business. So I'm left with diy and what I can get done at local garages.
This seems ok then. Says 5.1, says low viscosity. I've seen similar claims from Shell Brake Fluid - DOT 4 all right, but the blurb has "low viscosity for ABS" - though all said and done, neither claims DOT 4 LV. I've only seen Pentosin and a couple other non OEM brands actually come out and say DOT 4 LV.
That stuff will be fine
thanks
-srs
Yes, it does.
I guess you missed my revised post. 4LV limits the max viscosity at -40C to 700.
In Europe Low viscosity DOT 4 is becoming the norm as all cars have had ABS for some time. One additional advantage is it makes gravity bleeding a more realistic proposition.
