Is All DOT 3 Brake Fluid the Same?
VA
Just found out I got one more car to change the brake fluid in. I found some unopened Nissan Super Heavy Duty DOT 3 and I may have to use it to have enough without going and buying more.
I used some Amsoil brake fluid and some ATE Type 200 in my changes over the last week. I have 2 bottles of Amsoil which says "Synthetic" and was figuring on mixing the Amsoil and the Nissan for this last brake fluid change.
Aren't all brake fluids "synthetic"? Are all DOT 3 Brake Fluids the same?
This is just me but I wouldn't recommend it. Had a Mazda I was flushing the brakes on. Put a non-Mazda fluid (that supposedly met specs) in the siphoned out master cylinder and had an immediate reaction, glops started forming right away. Must have reacted to the little fluid that remained in the MC after siphoning. Siphoned all that out, got some Mazda fluid and no reaction. I can't imagine what happened but after using the Mazda fluid I finished the brake bleed with no problems.
Since that incident I've only used manufacturer branded fluid and had no problems.
No they are not exactly the same chemically. They are only all guaranteed to meet the DOT spec which is mostly a performance measurement/spec but probably affects some parts of the chemical makeup too (like whether it's silicone-based). Manufacturers are free to put whatever additives they want in there to meet the DOT spec or exceed it. Honda frequently claims their DOT 3 brake fluid is "heavy duty" implying they exceeded the standard for protection of seals and corrosion.
So in short, what brand you choose can matter but you can be rest assured if they meet the DOT spec you're looking for at least they meet the baseline. You will probably want something above baseline though.
It's hard to say, really. In theory, the bulk chemistry of a DOT 3, 4, 5, or 5.1 are roughly the same across manufacturers. They do differ between DOT spec of course... one is silicone, each has a different tenacity for water, and different boiling points.
But a few years back there was a to-do with either Honda or Toyota due to incompatibility of seals with fluids that didn't have their additives.
I believe all brake fluids are synthesized. They aren't refined products at least. So the use of the term synthetic is really a sales tactic.
I mix DOT 3's all the time. Prestone, AZ, AAP, Super Tech (ST). They all work. I've stuck with ST lately since they're usually the cheapest. As long as it meets spec, works for me.
Except silicone based fluid must be labeled DOT 5, and is not compatible with DOT 3, 4 or 5.1 .
Is all DOT 3 brake fluid Identical, is tough call. There can be slight differences from one mfg to another. Can they be mixed without issue? Yes, with no problems at all.
The Dot number is a spec, not a formula. So if it says it meets Dot3 for example that means it must have a dry boiling point of 401 °F and wet boiling point of 284 °F.
I've noticed many Dot3 either are very close to Dot4 minimum spec or even go a little over.
But as long as it meets the spec, or better, that your car calls for it will be fine. Minus Dot5 which is silicone. Yet Dot5.1 is not and can be used in Dot3 or 4 systems. Not sure what genius thought that was a good idea.
DOT specs are just specs and define the chemical basis for a brake fluid. But there are differences between brands. Supposedly Japanese fluid is closer to a DOT4 chemically and adds in another ingredient to help lubricate seals.
There are only a handful of brake fluid suppliers in the US/Europe/Japan. Dow, CCI, BASF and Clariant are the main suppliers. ATE, Bosch and the German OEMs and probably Castrol get their stuff from BASF and Clariant. CCI is the Japanese supplier of choice but they also have contracts with a few bottlers as well. Dow got their business from Union Carbide.
