Some conventional oil base can be separated out of crude with no chemical change, thus not synthetic. If cracked from higher fractions, you can deceive the public by calling the same thing synthetic.
All except the silicone brake fluids are polyglycols, which have undergone several chemical changes. It is less deceptive to call them synthetic, but still marketing hype.
While you can mix any polyglycol based fluids, I don't. I pick a product and stick with it. I haven't used anything but Prestone DOT 4 since 1966. It was labeled disc brake fluid then.
