My mother's 2004 Toyota RAV4 2WD has a leak of some sort that accumulates on the bottom of the transmission. I first noticed this a few years ago when changing her oil. At the time, I checked all of the fluids and found them at their maximum levels, so I degreased the entire area and decided to keep an eye on it. About 500 miles later it was dry. Again at 1000 miles it was dry. When I changed her oil 5000 miles later, it was wet again, but all the fluids looked great without any noticeable drop. I degreased again, took some pictures, and asked some mechanic friends. They were stumped.
Fast forward to the next oil change about 5000 miles later and it was completely dry and clean! There's been an irregular pattern ever since -- dry for 5K to 10K miles -- and then it starts leaking again, but never enough to drip onto the driveway.
Besides being suspicious of the transmission pan gasket, the brake fluid reservoir is directly above this area. In the past I never detected a drop in brake fluid, but today it is down about 1/4" from the MAX line where it was 6 months ago after I bled the brake lines and refilled. Pin hole leak, perhaps?
Unlike motor oil leaks which turn into a paste and retain a little bit of the brownish color, this stuff is much lighter consistency, always wet, always 100% black, and never forms a paste when mixed with road grime.
Any ideas?
Any ideas?
