Work was throwing out a Dewalt pressure washer with a Honda GX200 engine on it. I remember them buying it in 2017, I bet it had about 15 hours on it before the pump went bad. It got shelved when they bought another one and has been collecting dust since.
While doing some spring cleaning this year, it was headed for the dumpster, so I collected it. Despite sitting for years, the engine fired up on first pull but the AAA brand pump on it would do nothing but put out static pressure.
Went on Amazon and purchased a Triplex pump that wasn't made in China. Much larger unit physically (same specs though, ~3GPM, 3400PSI) made in Canada. It barely fit-- has about 1/4" of clearance between hose fittings and the frame. Bolted up nicely but can't test it until I get some washers (fitting on the pump has slotted holes) and an adapter to change from the quick connect fitting (new pump) to the regular screw on type so I can use the hold/wand that I have.
Have some home projects to do (deck refinishing primarily) where my converted diesel pressure washer just doesn't have enough juice. This "new" unit should fit the bill nicely.
