Hello BITOGers..
I just inherited the said pressure washer from my grandfather amongst other tools.
The B&S pump was clapped out struggling to build pressure.
I got a deal on a pump from Home Depot. It's a 3100psi 3/4 shaft from Home Depot.
http://www.homedepot.com/p/PowerFit-Hori...31098/204303150
Friend says it will fit but I want to know if the lightly used Briggs 3.5 horiz shaft will handle the load of a 3100psi pump?
I installed it today, the portable washer was hopping about violently from the increased load while washing.
Should I turn down the pressure valve lower and leave it?
Funny thing happened as I started the engine, a portion of hose sprung a pinhole and soaked my face w/ high pressure. Apparently the hose was worn or wasn't up to the extra psi?
I set the orig B&S pump aside to be rebuilt eventually. Parts are hard to find.
Thanks for any advice or suggestions.
Ps I'm mounting it to a nice little Sears vert mount rolling chassis. No hopping washer that way.
Mike
Mike
