Hey guys.
I have Ryobi 3100psi pressure washer with Honda GSV 190 motor that I got used long time ago. It's always been kind of funky at the begging. Starts good. Sometimes when it doesn't start on first or second pull it'll build up pressure in the line and I'll have to squeeze the trigger in order to be able to start it. Once that happens it'll have to run for a minute or so before I squeeze the trigger without it bogging down. It had an oil leak from the crank shaft pin so I replaced the O ring, checked the valve clearance and changed oil and spark plug. I've started it the other day and it started very well and at idle it ran smooth. But really struggled at first after I pull trigger. It bogged and died multiple times before it got to operating temp. After it warmed up it was running fine. But until then.... Not so fine. I though it was a problem with pressure relieve valve, so I took that out checked (not much cleaning needed) lubed it and put it back in.
Should I mess with the carb or pressure/choke linkage? What else should I look for in those pressure washers? After warm up it runs great! Has power, solid stream, no backfire, trigger responsive without bogging down. Just in the begging a little struggles.
