Preparing used brake rotors for new pads
I've done a few "pad slaps" in my time. When the rotors are in good shape with no grooves or gouges. I have only used sanding disc's a couple of times. They were quieter when I did that and no squealing.
Now days it is just about cheap enough to replace the rotors if I'm doing it myself.
If my car has open wheels, which mine all do. I can’t stomach looking at salt licked rotors any longer than a few years. My 03 Altima was the last car I owned that weren’t open wheeled and did a few pad slaps which amounted to doing nothing to the rotors. Never an issue.
I was shown at about 14 to rough up old rotors with a rol- lock sanding disc. Always worked well for me.
I see others just put new pads on the old shiny rotors.
Thoughts?
Roloc maroon discs for years. Strips any old transfer material/glaze like magic and cleans/conditions the surface for new pads. Never slap without them.
Agreed although I'd use the Velcro backer on a 4.5" angle grinder.
Mostly pointless since the pads will polish the roughed up surface. The lip is rarely an issue but a die grinder with a flat sanding pad or the carbide bit if I already have one set up on a holder to quick swap on the lathe takes the lip off but i don't bother doing that to a 1-2mm lip anymore.
I have never seen a factory service manual specify the procedure you're describing. Smoother is generally better for pads, most ceramic pads have minimal ability to cut thru a rough surface finish.
Most won't, easier to sell new rotors. Smoother IS better and is exactly what the Rolos provide. Without the shiny glaze or excess pad material. Just nice clean surface for new pads to get all intimate with 😁
I’ve seen a GM or BMW service bulletin that recommends not refinishing a rotor if all is being done are new pads. Unless of course, it’s scored deep. Finding someone who can cut a rotor without introducing more play/slop is hard these days.
Unless it’s a truck, European car or something with “performance” brakes, organic brake friction really doesn’t wear down rotors and they need to transfer a thin layer of material onto the rotors for cohesive friction. Semi-met/low-metallic pads will wear down the rotor as time goes on. I’ve pad slapped two cars without issue lately.
I usually just spray the old rotor with brake cleaner, give it a few scrubs with emery paper, then throw the pads on. If your rotors are warped, nothing besides resurfacing will help.,,,
Resurfacing won't un-warp warped rotors... been there, tried that...
