Other than the silicon ADBV, is there really that much difference between these two? I have a L14459 and a PL14459 in my garage now. Looking at the box, the Premium Plus says it filters 96% with the SAE multi-pass test performed at Purolator labs. The Pureone says it filters 98% with the SAE multi-pass test performed at Purolator labs. Is the 2% that big a difference to justify the $2.99 vs. $5.99 price tags
? Are these the same SAE tests, or are they different...I can't find any SAE test numbers? I know the Pureone has silicone ADBV, but for 3,000 mile oil changes...does this really make that much difference?
Taking the filters out of the boxes, they look identical inside (from what I can see). Same center tube, same base plate, same can-different paint job.
I plan of running each one and seeing if there is any difference, but I probably won't be able to tell. After the run, I will cut them open to see what they look like on the inside (I'm to cheap to cut open new filters
Just a thought...wanted to throw this out...what do you think?
Brian
Brian
