Hootbro Joined Aug 25, 2003 Messages 4,515 Location DELAWARE Apr 23, 2026 #21 QwikKota said: That is a hefty spring for an oil filter. For the bypass valve I assume. Click to expand... Spring is to keep the inner element aligned and pressed to the base plate. Has nothing to do with the bypass
Q QwikKota Joined Jun 17, 2015 Messages 514 Location Seabrook, TX Apr 23, 2026 #22 Hootbro said: Spring is to keep the inner element aligned and pressed to the base plate. Has nothing to do with the bypass Click to expand... Ok, thanks. On some filters they don't they use a spring behind the bypass?
Deplorable Joined May 16, 2015 Messages 825 Location Louisiana Apr 23, 2026 #23 QwikKota said: That is a hefty spring for an oil filter. For the bypass valve I assume. Click to expand... That spring just puts pressure on the internal parts to keep them together and against the base plate. The BPV has its own spring.
Deplorable Joined May 16, 2015 Messages 825 Location Louisiana Apr 23, 2026 #24 Here’s the picture of the spring from another PG filter. It’s contained in the BPV assembly.
Q QwikKota Joined Jun 17, 2015 Messages 514 Location Seabrook, TX Apr 23, 2026 #25 Deplorable said: That spring just puts pressure on the internal parts to keep them together and against the base plate. The BPV has its own spring. Click to expand... Thank you very much.
ZeeOSix $100 site donor 2022 Joined Jul 22, 2010 Messages 50,024 Location PNW Apr 23, 2026 #26 Snagglefoot said: Intuitively, it looks like the P type gasket would create a good seal but I don’t want to start an internet Bittog rumour causing a run on them! Click to expand... Both styles seal well if the filter is installed correctly.
ZeeOSix $100 site donor 2022 Joined Jul 22, 2010 Messages 50,024 Location PNW Apr 23, 2026 #27 Deleted ... already answered.
sauberes Öl Joined Feb 17, 2021 Messages 10 Location Cincinnati OH Jun 2, 2026 #28 GW. said: Looks great! Click to expand... I paid more for a Premium Guard PG461ex for my 2020 Outback 2.5L w/o turbo more than a Mobil 1 filter.
