I was thinking of ordering a Premium Guard extended life oil filter off Amazon, I seen something on them on Whip City. What do you all know about them?
Thank you..
Thank you..
Nothing like that by me...Might look into the MicroGard Select [Extended Life] at O'Reilly Auto if you have one close by. Might be the same filter made under a different name.
That is an ecore design now.The AutoZone STP XL (Extended Life) filters have looked well built per the C&Ps posted here. Their efficiency isn't bad either.
The one Stude cut open (I added a link above) had louvers. Haven't seen any STP XL lately. Are all STP XLs now eCore, or only some models?That is an ecore design now.
They are not the same size as a factory filter. Half the size.Can't go wrong with supertech filters for almost any application if available to you.
