Premium Guard Ext Life - 99% at 25 microns, but micron rating is 42-60?
Short of coughing up several grand and sending a couple of filters (Premium Guard & Ecogard XLs) to Ascent to be tested like they did the PH10575 sized ones, it's all conjecture anyway-PG isn't giving out consistent, otherwise verifiable info anyway!
Exactly. For years here there was the consistent statement that Champ XL were 99% at 20um, because someone, sometime, got an email from someone at Champion labs that said so. Even though the website and box said nothing, and the Supertech MP variant said 99% at 30um. Is it possible it was 99% at 20um - sure, but only because it could be anything technically.
Yeah, and I was one of the posters that shared those details. We're just trying to get a more accurate picture, where possible. BUT it is questionable if media is that efficient in every filter. Maybe 30um and 99% is the average for the line and 20um 99% is their best in some of those filters? Not the worst for the price. PG could be more clear, but it IS wierd to have statements such as the MG Select or the Carquest Premium as opposed to the data PG states on their self-branded offerings. Confusing.
I quite like the champ XL and continue to use it. I believe you did get an email from them. I just wonder what the info sent is actually pertaining to. A specific unit ? The whole line? Etc.
Need a sanity check here. Based on the recent Fram QC issues, I’m looking for another high efficiency filter for my cars.
Premium Guard Extended Life (and its rumored twin the Microgard Select from O’reilly) claim a rating of 99% at 25 microns. But, on the same page show a “micron rating” of 42-60.
What’s the difference between these ratings?
https://www.pgfilters.com/product-catalog/product-page/PG4612EX/2023-Honda-Accord/Oil-Filter/
After thinking about this for a couple months my opinion is the “Product Specifications” are the OEM specs. Which PG exceeds efficiency wise.
On a side note I also can’t get an email response.
Actually, they don't claim a rating of 99% at 25 microns. They claim "99% Multi-Pass efficiency and removal of particles as small as 25 microns". If challenged, they could back up that claim by showing that they ran an oil sample through the filter, say, 1000 times and sure enough, got 99% the particles out of the oil, including a couple that were "as small as 25 microns" once the filter was sufficiently plugged up. The wording reeks of marketing weasel wording. The "Product Specification" section is probably off of their spec sheet from the engineering department, doesn't have any weasel words, but does omit the percentage blocked in the micron range given (42 - 60).
This is eerily reminiscent of what I uncovered recently regarding the Purolator Boss. They had a very similar disconnect between their spec sheets and their website marketing claim. When I challenged this at to the top level of the company, they admitted that the spec sheets were the correct numbers:
https://bobistheoilguy.com/forums/t...ashlight-test-in-canister.386911/post-7125977
PG's apparent solution to the problem is simply not to respond to any inquiries.
I am wondering how widespread this sleight-of-hand is being practiced in the oil filter industry ...
I am wondering how widespread this slight-of-hand is being practiced in the oil filter industry ...
They also include per ISO 4548-12 so that should eliminate modifying the amount of passes. But yes no filter model mentioned and I’ve sent multiple emails without response.
Think it's just a matter of wording. Any filter will remove some particles "as small as" even down to 5u or less, so a filter would have to be a super rock catcher to not catch any particles below 25u. I think they really mean @25 microns and larger. And I've also tried to contact them through their website a couple of times and all I hear back is crickets. 🦗
https://www.pgfilters.com/products/filters/oil-filters/extended-life-oil-filters/
Why does everyone say Premium Guards are the best and trust them when they are a foreign company that will not return any information? I also looked at their website and it appears that the regular Premium Guard has a lower micron rating (15-25) that the Premium Guard Extended Life is 42-60 micron? I get the multipass efficiency stuff I think, but does this make sense?
Premium Guard
  • 96% Multi-Pass efficiency and removal of particles as small as 20 microns
  • 15-25 micron rating
  • 99% multi-pass efficiency** removes particles as small as 25 microns
  • 42-60 micron rating
Premium Guard Inc is a US company out of TN with a research and development facility in MA. They use VAFI overseas factories to build the filters. Currently the quality is second to none.
I agree it’s discouraging not getting email replies. It’s not just PG not returning my emails. Sometimes a call works better.
As far as the efficiency, I go by the official ISO 4548-12 numbers. IMO the strange micron numbers are specific for each model and are probably taken from the OEM filter spec sheets which they exceed.
Premium Guard
I remember once being advised by a lawyer that in corporate contracts and statements (e.g. insurance contracts) all ambiguity is in there for a reason, and it is usually not in your favor.
That was the point I was trying to make, and is it all BS marketing not backed up by testing? I have never used these filters but just started looking at them since that is all you hear about now on this site.
An office in the USA isn’t making them. I have to be against the all you hear about is PG. It really is a bit much. There are still choices, and the car will be fine. Made anywhere besides PRC or Vietnam is my filter. At least I try to filter it, not easy. Nothing has stopped the outsourcing since it started, maybe in the early 80’s.
Premium Guard
I understand and do not disagree with your skepticisms - its a matter of lack of better options.
M&H (owner of Wix and Purolator) have shown they clearly do not care about quality one iota based on C&P here. They don't respond to questions either - including questions about possible fakes. That is something you would think they would want to find out - but crickets.
Fram has had some pretty abysmal C&P here also, they change designs of filters back and forth constantly - ie nitril ADBV on a filter spec'd for silicon - so can we be sure the media is as spec'd also? I don't. Their parent company has had their bonds de-rated to junk so I am sure there being starved for cash which is never a good thing.
Race to the bottom for sure.
The C&P on the Premium guard options have all looked impeccable. So at least you have that.
So you get what you get. Some have recommended Donaldson - so I may try those next. Trying to use up what I already have first.
@SC Maintenance said it well.
You buy what looks good on the inside as I myself have done on many versions of PGs..
Fram blew it when they messed with the original Ultra...what a foolish decision....the king of filters became just another ho-hum filter not worthy of buying.
As a matter of fact the first case of PGs I purchased got me so excited I ended up in the ER. With an embarrassing injury.... I won't bother to further explain... 😌 🙂 😆
