Got the oil changed last night. The oil ran 15,496 miles. Conventional MC 10W30 Super Duty HDEO SM/CJ4. P1 filter in there the whole time, 10K of that with a Racor ABS bypass installed (3um absolute). I have three samples to send off for tests, two for used oil analysis (two different labs) and one for an optical PC. Should be interesting to see vs the 5K and 10K tests.
Installed the last of my Castrol GTX 5W20 (SM from about 2008), which will be the test oil for the filter tests. Installed an MC FL820S as a baseline. Will run that 10K or so.
I finally got around to installing a Fumoto, which will greatly simplify sampling from here on. I had to resample once because I picked up grunge stuffing a sampling hose down the dipstick tube. No more-o-that!
Didn't datalog the short test drive, but the drop in oil pressure is notable between the 10W30 and the 5W20. I only got to 185F EOT and the pressure at my 1750 rpm (60 mph) test speed was 64 psi. At that temp, I am usually around 70 psi with 10W30. DP at that rpm and EOT was about 2psi on the gauges with the MC filter. The P1 with 16K miles at the same temp and rpm with 10W30 is about 4-5 psi. I will have to make sure and test a fresh P1 in this cycle for comparison with the lighter oil. I installed the DP gauges when the P1 had about 10K on it, so I have not seen it in a new state ( with 10W30 or 5W20).
I was interested to see how much of a difference in oil pressure there was between the 5W20 and 10W30 conventionals. I had a high VI 5W20 syn in there previously and it would deliver about 63 psi at the same rpm and oil temp.
