Originally Posted By: ShotGun429
we store cars here for people... in a enclosed heated building, dont mess around pulling plugs and shutting off fuel pump,on fuel injected cars and trucks. just start it up, if its a older car with carb and a flat tappet camshaft,and you want to crank it over to build oil pressure, DONT!!! the cam needs dipoff lube at once. cranking (with out starting) is the worst thing you could ever do to a older car.
What's "dipoff lube" mean?
I'm guessing you mean that the oil pump won't be effective if its cranked without starting. I hope you're not right, (but you might be) because I've done this quite often.
Dunno how much difference it makes, but with the plugs out it cranks a lot faster (subjectively assessed) which I'd hope would mean the pump was pumping.
I suppose I'd have to try it with the rocker cover off to find out.
