(sorry if this is long, haha)...My last oil analysis (and all previous) was with M1 0W-40 runs.
Heres my last UOA Thread
I had decided on giving a 5w-30 oil a shot in the winter for a couple reasons:
-Oil spec is 5w-30 / 5w-40
-Although M1 0w-40 has a generally accepted superior formula, esp in extreme hot or extreme cold, I was hoping in ~0-10 deg C days here in PA that the lighter 5w-30 would prove beneficial on wear AND especially MPG while i drive around in sticky winter tires
-just wanted to experiment in general and a short winter OCI was a good time for that
The below is the Blackstone report of my Pennzoil Platinum 5w-30. I went with PP solely because it was on sale and felt like giving a different major brand a go. I'm still running the OEM oil filters like all my previous UOA. This UOA was done on the 2nd 3k OCI of PP 5w-30...There was also a 5k OCI of M1 0w-40 also not analyzed. So the engine has 11k miles more break-in since the last UOA.
At first glance it looks great and the comments talk towards that too. I agree for the most part. The most encouraging sight for me is the lower fuel dilution. I'm not sure I can attribute that to the oil though. Here's the UOA un-marked up:
Alright, the 1st obvious thing is that after 3k miles its down to a -20 weight oil, below spec. Not a ton but still under. I will run 5w-30 again next winter most likely based on the report, but never more than 3k miles.
The 2nd obvious thing is that they are comparing and giving glowing reviews of the measured PPMs with M1 UOA samples with 2k+ more miles OR were early in the engine's life & during break-in.
Not necessarily fair...again though, i'm happy with what PP did.
3rd is what Blackstone did not know, the driven conditions & maintenance since the last UOA....
This OCI saw a good amount of HWY miles. I track my MPG and other "stats" each tank in a simply excel sheet, and I scale/weight accordingly...My lifetime average speed per the comp (with proper weighting) is 38.4 MPH (my overall fuel avg at that speed avg is 24.3 mpg, FYI) . On this UOA's OCI, during those 3k miles I had 3 tanks (1066 miles) that averaged more than 10 MPH above my average speed. Basically at least more than 1/3 of this OCI was on long, non-standard HWY trips...THAT certainly attributes to my lower and "best" wear figures so far.
...ALSO, I upgraded/changed both my spark plugs and PCV hose. The spark plugs are to be replaced every ~30k (severe conditions) in partial thanks to D.I. and the factory PCV had the tendency to collapse depending on heat. I'd like to think these two might have helped some with engine health, wear, fuel dilution?..
...Lastly, due to the electronic wastegate on this turbo car, the voltage for the actuator that the ECU "expects"/checks for at start-up is thrown off during "cold" starts. It basically throws a code when colder than 40F out and the engine is cold. There's a fix but I've been lazy and havent done it nor taken it to the dealer. ANYWAY long story short is that to by-pass this issue I simply changed my cold-start driving habits. All winter I've woke up, got the dog up, started my car, and walked the dog while it warming up ~5 minutes or more. When I get back from the walk I turned it off, got ready for work and then start it up again (no code AND ~ 120-130 F engine temps) and THEN drive off. Much more gentle than I was in the past, prior to the wastegate actuator "issue". I strongly believe I'm reducing wear metals by not driving away 30 seconds after a 20 deg F start-up. I plan on continue this warm-up routine.
Here is my same report as above but applying a linear estimate for 5k miles. This is actually going easy on the PP because I would expect wear to not be linear but get worse and worse over the oil's life, especially with the fact it was already down to a _w-20 after 3k miles. On the right is the average of the last (2) 5k mile UOA on M1 0w-40 to compare to the PP 5w-30. Remember, the PP is with 11k more mils of break-in.
So what do you think?
All in all, the report proved at worst that the PP 5w-30 is serviceable for 3k OCI, at least in the winter...and at best, it may be better... maybe.
I think the report also makes clear that if I want to go 5k OCI or longer (which i do), then I ought to stick with 0w-40. That's my plan. And with new warm-up procedure in the mornings & engine break-in, I expect the next UOA of M1 0W-40 to be at least on par with the PP 5w-30 (in 5k OCI terms), hopefully much better.
