So aside from the amount of labor hours, is this unit worth repairing? I dont mind the labor hours as I enjoy working on small engines.
It needs a clutch as one of the springs broke, and a piston ring. The cylinder and piston look like new with no scratches or signs of dust polishing however the engine is very low on compression. I assume the ring never seated in properly or has gotten stuck and therefor has worn unevenly. Another theory is the ring just has low tension.
Any any case this is clearly a homeowner grade low end tool, and I question if it worth spending any amount of money on......
