Fram haters, please don't turn this into a "I hate Fram thread".
This is an application concern.
Ok, I need some help with my diagnosis of a base idle lifter tapping problem I have had lately on my 1995 4.3L with a remote oil filter assembly which is behind the fron bumper.
The noise goes away immediately once the engine rpms are picked up and the pressure increases.
Since installing the Fram X2, at idle the lifter assembly seems to be making more noise than normal when at warm complete idle.
Now I also notice that my oil pressure has been a little higher lately since installing the filter as well.
Don't get me wrong, I don't have any cold start knock even at -30f so I don't think that is a huge concern.
My concern is based on the fact that the synthetic media might be hindering the flow enough that I am not seeing proper top end lubrication when at hot idle.
This is the construction of the X2.
Now seeing the synthetic media does filter very well, I am wondering if it is filtering just too well and not allowing enough flow when compared to a standard well built paper element filter.
I can see this filter having no problems when it is screwed directly into the block like the 1994 Cavalier I use this filter on as well, but I think I might be too much filtration when compared to say a K&N oil filter like this below:
Seems to be a little easier getting oil through that filter and it does flow better.
What do you guys think.
Just for a wrap up, do you think the X2 might be a little too restrictive for a remote oil filter setup?
