Post your rpms at 70mph
5 speed auto in the 08 G37 about 3050 rpm @ 70 mph
Wife's 1 litre Toyota echo screaming at 70 mph
Originally Posted By: mattwithcats
2000 RPM's at 70 MPH in an 2002 Saturn SL2.
However, 5th gear has been swapped from a .730 to a .605,
dropping the RPM's by a thousand....
that's interesting. Does it help your hwy MPG?
2000 Jetta 2.0l with 5 speed manual is 3,500 RPM at 70mph in 5th. My foot is only stepping 1/4 on the accelerator. Car will still climb hills like it is flat. It likes to run at this RPM.
Originally Posted By: ThirdeYe
Going by memory, but I believe my 95 Acura Integra LS is at around 3,000 RPMs at 70. 4-speed automatic. 1.8L I4, 142hp.
I can't remember what the Firebird is spinning at 70mph. I know it isn't nearly as high as the Acura. Probably around 2k. I'll follow-up with a correction if I'm way off. Also a 4-speed auto. 3.8L V6, 200hp.
I was close. The Firebird is at about 1900 rpms at 70.
Originally Posted By: Clubber_Lang
Originally Posted By: DAC17
2014 C7 Corvette = 1300 in 7th gear!
A fast idle at 70. love it.
Wow, that is amazing. No wonder it can achieve 30mpg on the freeway.
3300 - 3400 in the Fit. Used to be annoyingly loud at those RPMs but seemed quieter now that I'm using PU. Could just be placebo effect. Really wish it had a 6th gear.
2500 in the Taurus
About 2400 in the Dakota, which has 3.90 gears.
About 7100 on the Burgman.
Not sure on the Caddy, which has no tach.
F150 @ 1950 rpm. That has a 3.73 rear end, so it's only getting about 18-19 mpg unloaded. (not to mention it's a crew cab)
Saab @ 2400 rpm. That will reliably get 32-33 mpg at that speed.
C3 tops out at 39 mph…and the Kawasaki at 62!
