Can't believe it's been nearly 5 years since I took these of Big Boy when he came to Denver.
Agreed - and when the wife and I went (one-way train, bus return), we booked the Parlor Car, which enabled some great shots of the train and unobstructed views out either side and behind the train:The Cumbres Toltec is WAY better and I think prettier. Seriously.
Look at those cylinders. Good grief.The only surviving example of what I consider the finest steam locomotive class ever built, and yes I will die on that hill
Unfortunately, between overall condition, lack of general interest, and the suitability of this sort of locomotive for excursion service(built to haul 100+ car coal trains over the Blue Ridge Mountains at 25mph) I don't think this one will ever be under steam again. Never say never, though-this is one of maybe a half dozen true Mallets surviving in the US(front cylinders use low pressure steam exhausted from the rear cylinders) and I thought none would ever run again, but C&O 1309 was restored a few years ago and is currently running excursions
Do you know what kind of grade it was capable of pulling? That is very huge for logging work. Shay locomotives are generally far smaller, although I read one weighed 140 tons. Is anyone going to post pictures of their local Shays?On tour in Oregon in 2010.
Conrail was awesome! Certainly more colorful.
And soon the Pegasus is(probably) going away...From last July. I miss seeing Conrail Blue here...
I understand the Army uses a lot of of vintage units for the local operations. CVS or whoever transports the long hauls.
It was built in the 1950s, then rebuilt in the 70s which is when they added those vents (there's filters inside there) and improved crew visibility by adding those extra front windows which it didn't have originally.IDK much about trains but those curved vents behind the bell make it look like a much older unit. I bet from the 70s or earlier.
https://en.wikipedia.org/wiki/EMD_GP10
Amazing it didn't have front windows when new! Is it true the bathroom is inside the nose?It was built in the 1950s, then rebuilt in the 70s which is when they added those vents (there's filters inside there) and improved crew visibility by adding those extra front windows which it didn't have originally.
This unit got its chopped short nose in a rebuild. EMD started offering a low short hood with the later GP models. The factory hoods sloped down towards the front, while the modified were flat.Do you know if this particular one was ordered as high nose and chopped, or did it come out of EMD as a low nose? I don't know enough about IC to know how they ordered their Geeps(and I tend to like mountain roads that preferred high nose, long hood forward as delivered).
