Post your locomotive shots
Brill Doodlebug on the Old Colony & Newport in the mid 70's or so. My Grandfather, retired Navy Senior Chief, WWII submarine vet and a huge formative part of my life, and Grandmother took me for a ride. It was mid Summer and a beautiful day. My Grandfather talked the operator to letting me sit in the jump seat adjacent to the engine and generator, a massive straight engine. There was a small window, on the other side of the train in this picture. I remember somehow looking back and seeing my Grandfather with his arm around her, smiling. Just a great, great day.
Not my pic, pulled it from the web ages ago (see credits), but it would have been around that time and it reminds me of how good those days were.....
To the Mods, LMK if this is a problem as I have other pics, just not as good.
BNSF crossing the Clark Fork River in western Montana.
Great photo. Here is some Trivia. The Clarke Fork feeds into the Columbia River in the Pacific, but the headwater of the Clark Fork near Butte, Montana is not far from the headwater of the Missouri River near Bozeman, Montana, which feeds into the Mississippi and then into the Gulf of America near New Orleans. The distance between Butte and Bozeman is 85 miles. :D
Here’s a shot for historical reference for train fans. It’s a CP ( Canadian Pacific) locomotive with a KCS ( Kansas City Southern) locomotive coupled behind it. CP purchased KCS and the company is now called CPKC.
This particular train is waiting to head south into the USA, crossing from BC to Northern Idaho. The common items going south are crude oil, potash and lumber. Just after I took the shot, a train pulling empty oil and potash cars went past going north. The oil cars end up in Alberta and the potash cars go to Saskatchewan.
America’s most northern line is the BNSF (Burlington Northern Santa Fe). It more or less runs parallel to the USA/Canada border. You often see locomotives from both companies on the CP tracks up here. Enjoy the shots.
Just saw CP and KCS locomotives pulling a long all livestock car train. What was interesting is there must have been over a half dozen train companies marking the “cattle cars” …
The cars may be purchases by multiple buyers. Blocks of cars with different reporting marks based on purchaser and quantity. Or, failing that, they may be cars marked from earlier, extinct roads that were absorbed through mergers and acquisitions. Could be any number of reasons. N&W and Southern haven’t existed for decades, but I’ve handled countless coal hoppers with these marks.
Hope this counts. Rode this bad boy hundreds of times as a kid, plenty as an adult as well. This is the railroad ride at Kings Island. My friend tends bar at the restaurant a short walk from the station...... last fall, I think it was late September, calls me and says "You coming up for the Halloween thing tonight?" and I said no, my other friend who was going to go with me wants to postpone until tomorrow night. Friend said "Bummer, a bunch of people came into the restaurant and said they just saw Scarlett Johansson waiting in line for the train". Ooofmph! I always miss the good stuff.....
Anyway, this is a propane fired American 4-4-0, somewhat based on the General.
There is a place in Yellowstone National Park where a creek splits and feeds both east to the Missouri and Mississippi and west to the Snake and Columbia. The place is Two Ocean Pass and oddly enough, the creek is Two Ocean Creek.
There is another spot in the Canadian Rockies where the same thing happens.
Cedar Rock RR close to Round Rock, TX. 1/4 scale. When we rode it they had converted it from the usual gas engine to electric. Pretty sweet conversion-Lipo batteries, good run times the guy told me.
The front cylinders are 39" diameter(32" stroke). Rears are 25" diameter.
For comparison, the Big Boy uses 23.5"x32" cylinders(all 4).
A Y6b could manage 170,000lbs of starting tractive effort in simple mode(feeding high pressure steam to the front cylinders). Through the 1950s, when N&W would bring any Y5, Y6, or Y6a in for overhaul, they would add in as many Y6b improvements as they could, so that by retirement, most of these locomotives had similar performance. 2156 reportedly made 166,000lbs TE after its last shop visit in 1957. In compound mode this dropped to 125,000lbs. The Big Boy managed 135,000lbs of TE, but was also longer by ~20ft and over around 300,000lbs heavier. The Y6 class packed a lot of punch for what was actually a relatively small locomotive.
I love this video of a Y6b and Class A, with a Y6a pusher, getting a 175 car train over the "Blue Ridge Grade"(8 miles, 1.2% outside Bluefield, WV).
At the start-is that the equivalent of running "rich"?
With the black smoke?
More or less.
Firing a coal fire is a skill, and usually black smoke gets assigned as "wasting coal" or "inefficient combustion."
My GUESS in this case, and the N&W engineers and firemen did nothing but run this grade all day in these locomotives, is that you're seeing the result of the fireman REALLY loading up the fire before the start of the grade, and it consequently cooling off and not burning as efficiently. The N&W ran coal from the mines they served, which was primarily fairly high grade bituminous coal. Bituminous basically burns in two stages-the coal initially "cokes", driving off the volatiles that burn in front of/in the flues, and then the remaining carbon gives a long lasting stable fire.
Adding coal always disrupts the process a bit, so on flat land at steady speed the fireman would likely add small amounts of coal continuously(using the mechanical stoker-there's no way even 2 or 3 people could keep up with hand firing one of these beasts).
Climbing a grade that steep with that much tonnage in tow is going to use a LOT of steam, and you need a stout fire to keep up with the steam demands, plus that much steam is going to translate into a lot of draft that will help the fire recover quicker and also risks pulling the fire up off the grates if it's too small. Loading up the fire ahead of the grade would probably be smokey at the start, but you also have 8 miles ahead of you to drag out at ~20mph, and you really don't want to miscalculate, find yourself with too small of a fire halfway up a grade, and then have to over-correct and maybe find yourself not even able to make enough steam to keep moving before you get to the top.
I'll also mention that now, when you see a steam locomotive running, people expect black smoke. They usually will intentionally make it for photo run-bys and the like, although hopefully won't run the whole trip that way.
(on oil-fired steam, even if the mix is less than optimum, the fire is rarely sooty in the way a coal fire is. Oil does need to have the flues periodically cleaned, and that's done by quite literally dumping a bunch of sand into the firebox and letting the draft suck it through the flues. "Sanding the flues" does give a great display of thick, black smoke, so many oil operators will choose run-bys as an ideal time to sand).
NJ Transit has a bunch of their old GP40 and other locomotives painted in Heritage schemes. I thought I saw one the other day.
Today, in rapid succession, a Conrail painted one, followed by a NJDOT (apparently a stopgap when the raildoads all failed) painted one, which is what I saw the other day.
Turns out there’s a website about these trains.
https://www.njtransit.com/heritage
Looking forward to seeing Big Boy on its trip east!
Union Pacific Big Boy 4014 is a VERY IMPRESSIVE sight to see if you are into that kind of thing. It is worth the trip to see it live & in real life action. It is and was the largest steam locomotive in the world, and the only one that has been completely rebuilt and currently in operation.
“The Big Boy” #4014 was built in November 1941 by the American Locomotive Company (ALCO) at its Schenectady Locomotive Works in Schenectady, New York. Union Pacific had 20 of this configuration manufactured. Here is a link to the schedule
https://www.up.com/about-us/history/steam/schedule
Passenger service with a GP40 in the lead. I didn’t know this was a thing.
Do you know if they are Wabtec (GE previously) or EMD'S?. The radiator and cab windows usually give it away.
Not a locomotive but a caboose at the former Elkmont Train Station, Elkmont AL:
The former rail line is now the Richard L Martin Rails To Trails in north AL. The line is about 11 miles from north Athens Al to the TN line.
