post your latest transmission lubricant change.
2018 BMW 530e
B46
126k miles
Original fluid out (dark)
Pan dropped twice to replace majority of the fluid.
Used LM Tec 1800
Never any issues with trans.
Also did front, rear diffs and transfer case oil.
Car is going down to FL with my daughter to medschool so pretty shore it's the last change it will see.
2023 Honda odyssey, 29,9xx miles
Drained and filled 10 speed auto. Honda ATF 2.0. Fluid coming out wasn’t very dirty at all.
With these dipstick-less trans, I’ve lately just carefully measured what I took out and replace it, but with Hondas transmission reputation and the fact that I’ve had a few weird downshifts and transmission behaviors bother me from time to time, I decided to check fluid level.
I drained only 4 quarts exactly out. Everyone online claims they get 4.5 quarts out. I had already eyeballed level of the van on stands, but I checked it with a 4 ft level as well, it was spot on. I filled 4 quarts since that’s what i drained and it wouldn’t reach the level check hole after warmed up and ran through its gears. Another 0.6 quarts went in and cycled again, checked, and a healthy trickle now came out.
4.5 seems to be the right amount, maybe mine was a little under filled from the factory. I doubt that 0.5 quart is making a noticeable difference in its performance, but at least I feel better it’s fresh and filled properly.
2008 Toyota Tundra in signature..
Out: Idemitsu ATF Type TLS-LV (4 quarts)
In: Idemitsu ATF Type TLS-LV (4 quarts & 4 ounces of LUBEGARD Red)
Hey snwrbrdr12, I'm not knocking you're Ody tranny, but is it that German tranny Honda was using for a few years, then switched backed to CVT after they all failed ????.....Just curious....I wonder if they went back to the drawing board on that German tranny, and are stickin them back in again....Honda screwed up so bad. My 13' CRV has the old school Honda tranny, and it now has something like 535,000 miles on it. Do a spill and fill, ( 3qts), every 25k. AND it actually has a real dipstick where you pour the new fluid into !!!!!!. Start it up, cycle the gears, wait for the fans to kick on, while running pull the stick to check level. Easy Peasy. IF it is a " newer" version of that German tranny, I wish you the best of luck with it.....but...it shouldn't be acting up at a lousy 29k. Friggin Honda. Not what they used to be. They turned into the 1986 Hyundai's. Real P.O.S.
The ‘23 doesn’t have the ZF transmission seemingly riddled with issues. It does have some odd spec transmission fluid Honda doesn’t like to release metrics for so we can go to good aftermarket options (HPL). Also, it’s not a cvt transmission. HTH
Lastly, yes - the level check for the fluid imo is a pia compared to a dipstick. But here we are.
It’s a 10 speed I think it’s Honda made. They aren’t known to be problematic even in guys hopped up 2.0turbo accords. I think it’s more of a programming / software / logic issue but I still like to maintain my stuff well and was interested in the fluid condition and fluid level once I didn’t drain as much as I expected. Checking fluid level and filling it really isn’t that hard, but it’s more work than a dipstick for sure.
2017 Ford C-Max Energi PHEV with 77,931 miles. Dealer performed a flush using XT10 QLVC oil. Had to Google that - apparently it's Ford's term for Mercon LV. I immediately noticed a change in EV throttle response when leaving the dealership. Does that seem plausible or are my senses or imagination getting the best of me?
Going back for another cvt fluid exchange tomorrow. Had to use some old Transmax Cvt and its sloppy so going back to the tried and true.
Changed today and the difference in only 1,000 miles is staggering. Recently I made a comment about cvt fluid being something that shouldn't be cheaped out on and after this recent service i am a believer that the boutique fluids do outperform and are worth it and the difference money wise is not that big of a deal. As Autohance has appeared to shutdown i will most likely be going over to @High Performance Lubricants
2005 Prius 265K
Friends got this little jewel for their daughter who is starting to drive. Easy to service!
The drained ATF looked really good, nice and red.
Pumped in about 3.5 qtr Idemitsu WS equivalent.
Also swapped air filters, service coolant and replaced spark plugs with Densos. Thanks @The Critic. The NGKs were ancient and 1 was cooked black. Will service the inverter next oil service. How do these plugs look? Thanks in advance.
2015 Toyota Sienna LE 6sp auto U660E transmission. 65K miles.
Drained 1.5qts (Total dry capacity, 6.94qts) Toyota WS ATF and refilled with 1.5qts Toyota WS ATF. Color was dark red. No strong odor or visual abnormalities. Changed at 85F outside temp with engine cold. Previous D/F at 60K and next D/F will likely be 70K. No driving issues after service.
