5.25 quarts ACDelco Dexron VI full syn/Carquest Filter Silverado 4L60E
Isn't the AMSOIL ATF pretty dark red new? I seem to recall that from my previous MB diesels and Chevy. Not using it in the current cars because got a sweet deal on Fuchs and Valvoline.
Where did you source the pan from?06 Toyota Matrix, 176k miles
Replaced the drain pan (old one had a dent)
Replaced filter w a Beck Arney
Filled w Toyota t-iv
Magnets had a lot of fuzz View attachment 114365View attachment 114366View attachment 114367View attachment 114364
It’s an aftermarket pan from Amazon, about $26, fit perfect but the drain bolt is a different size vs the factory. No leaking anywhere.Where did you source the pan from?
If aftermarket, what brand?
And did it fit right?
How did you determine which fluid to use? The local dealer hasn't been any help for my BMW and insists the ATF doesn't need to be changed.2013 Bmw X5 35i xdrive 117,500 miles
Drained out OEM ZF Lifeguard 8 fluid and dropped pan
Installed new ZF pan w/filter
Filled with 5.7 qts HPL Green Cold Climate ATF
Just got back from a 2900 mile road trip. Transmission had a bit of a hesitation from a dead stop before fully engaging. That problem is gone with new fluid and it shifts smoother as well.
How's this working out?2013 Bmw X5 35i xdrive 117,500 miles
