Post your latest small engine oil change
1987 John Deere 214 K321 (Hours Unknown, all original)
Out: 2qts Rotella T5 10w30
In: 2 qts Rotella T6 10w30
2023 Gravely ZT HD 52 Zero Turn FR691V (7 hours)
Out: 2 qts Kawasaki 10w-40
In: 2 qts Amsoil Small Engine 10w-40 w/Kawasaki Filter
2nd oil change was quicker than needed, but I wanted to swap the factory plastic oil drain valve for a brass hose/plug combo.
Champion 11,000w Tri Fuel Inverter Generator (5 hours)
Out: 1.1L Factory Supplied 10w30
In: 1.1L Amsoil Small Engine 10w30
Break in procedure with low-mid loads.
Champion 9000w Tri Fuel Inverter Generator (83 Hours)
Out: 1.1L Amsoil Small Engine 10w30
Ran 78 hours straight only stopping to check the oil level each morning/evening. Didn't burn a drop.
Predator 2000w Inverter Generator (30 hours)
Out: 13oz Mobil 1 10w30
In: 13oz Amsoil Small Engine 10w30
Honda EB6500 Generator
Out: 1qt Pennzoil Platinum 5w30
In: 1qt Napa Synthetic 10w30
Recent ice storm and 4 day power outage got all the generators a good workout and the 11,000w champion added to the fleet.
you guys had a heck of an ice storm there! I hope all is well and things are getting back to normal.
Late 90’s DR power walk behind string trimmer 5.5hp Briggs
Out: 10w30 Synblend HDEO I think
In: Xw30ish weight Full Syn. Frankenbrew of leftovers and bottle drippings
Free hand me down 2009 Lawnboy 20” push mower 6.5hp Briggs
Out: Unknown, guessing 30sae
Sharpened blade, waiting for new carburetor to arrive to finish off.
I have a 1967 Sears Suburban 12/6 with the HH120 Tecumseh.
The last oil change/service grease etc. was 14 years ago!!
Before you roast me you need to know I use synthetic oil and have never needed to top it up and it also looked fairly clean on dipstick.
It is only used to pull a utility trailer for yard work and grand kids.
Other than replacing the transmission drive belt last year it had been a trouble free brute that easily pulls my 900Lb wood splitter.
They don’t make them like this anymore!!
90cummins
Changed the oil in my parents John Deere s240 with the 18.5 HP Kawasaki vtwin.
Drained out I believe Pennzoil or Quaker State Synthetic 10w30, removed a Purolator tech 10241 filter
Installed a new Purolator tech filter and filled with Supertech 10w30 full syn
What's the PUROLATOR number ? Would it work with the B&S 22 H.P. Twin Cylinder ?
Not the guy that you replied, but the tech filter would be TL10241. I’ve ran the PL10241, which is just a higher end version of Purolator, in my 20HP Briggs V-Twin. They all cross back to Wix 51348. There’s also a bigger Purolator that’s about double the height that fits, that part number is somewhere on my previous posts.
Oil Change Coming up in a week. 2018 Cub Cadet LT46 with a Kohler KT725 engine, 23 horse.
Out: Amsoil Signature Series 0W-30.
In: Amsoil Premium Protection 10W-40.
Filter: An Amsoil EA15K53 stays on for the time being. It replaced a Purolator Boss PBL10241 in the fall.
2022 Gravely ZT/XL 42”
Kawasaki FR651V - 21.5 HP
Out: Mobil 1 15W-50, Kawasaki filter @ 92 hrs.
OCI: 23 months/68 hrs.
In: Same.
2nd oil change for the machine since I bought it new in Sept. 2022 (photo from Sept 2022)
We had it bad but the center of the state had it way worse. I travelled across state over the weekend and 90% of the trees East of Gaylord have no tops left. The roadsides are mulched up trees for miles. Temporary wiring and lines down across roads all over the place still.
This time I changed oil in my John Deere s240 with the 18.5 HP Kawasaki.
Removed a Purolator tech 10241 filter and drained out I believe quakerstate 10w30 synthetic
Installed a longer filter this time. A Mopar M0452, same size as a Fram ph3600. I bought a couple on clearance at Walmart years ago. Decided I should finally use them. Just enough clearance.
Filled with Supertech 10w30 synthetic
Correction. It had 10w30 Pennzoil syn in it that i drained
B&S powered push mower ((OHV)
Out: Frankenblend from my ‘odds and ends’ jug; mostly 30-weight oils. 2-3 years on it; very dark but not sludgy.
In: 400ml of Frankenblend from the same jug.
