Post your latest small engine oil change
The onan got up and running. had the engine seafom and mmo clinder soap. ran seafoam and lucas double dose first five gallons.
is set up to pull fuel out of 18gallon marine tank.
running twc-3 bulk oil @ 1oz to gal of petro.
18Hrs not a hickup. i have it out on a hunting lease.
the 1955 kohler 3kw light unit
out: unkown but believe the last owner said carquest 10w30
In: castrol "gold bottle" syntec titanium 5w-20 and purelator "fl-1a" oil filters.
i have a dual remote set up.
i would like to run the fl-299's.
jr
Ariens platinum 24 snowblower
Out: Royal Purple 5w30
In: Mobil 1 5w30
Not exactly an oil change....but my toro S200 that I just fixed up and got running (by combining the best parts from 2 S200's)
In: 50-50 mix of True Fuel 40:1 and 50:1 with a dash of MMO thrown in
iahawk, nice to see someone has kept a toro s200 going.
i have a s300 that has ran great on whatever 32:1 i have, ussually Pennzoil conventional twc-3 muti outdoor .
then i have a s200 i picked up dirt cheap. i need to get the carb kleen.
it runs good no load. but needs choke to run any load. . this one will be my new main machine and will get a diet of amsoil saber @ 100:1.
Ken
ps. i have a 12v starter on the s200 till i get a 120v. its started in the wood room so no coldstarts. 80+°F storage.
JR, thanks, love those old Toro S200's, too. I used one as a kid a long time ago and thought it's be great to have one again.
Found 1 runner on CL for $35 and 1 non runner for $20...ended up using the non runners motor..after a carb kit, some new gaskets, fuel line, paddles, scraper bar and drive belt and a good cleaning she's in pretty good shape for a 33 yr old blower.
Probably keep running premix as long as we don't get a ton of snow.
Milwaukee 4211 Generator (Generac) - December 1971 build
Out: Pennzoil conventional 30w
In: Rotella T 10w30
Dedicated propane conversion.
TroyBilt GTX18 tractor with a Kohler flathead 18HP twin.
Crankcase was full of gas due to a bad carb float....replaced float and changed my recently changed Rotella T SAE30.
Simplicity yard tractor with Kohler 14HP single cylinder (1999 model), Rotella T5 10w30, Motorcraft FL-910S filter
Simplicity snow blower with 10HP Tecumseh engine (also 1999 model) Mobil 1 Extended Performance 5w30, no filter on this engine.
Slowly working to all my OPE...
Tecumseh Shnow King 5 hp.
Out: something old and black, probably 2 years old
in: 1998-2000 Mobil 1 5w30. Almost the last of this. Pushmower will get the rest.
Granda's genny. Vintage tecumseh powered coleman 5kw+.
out: probably Pennzoil Conventional 10w30 / unkown hours
in: 2006-07 vintage AMSOIL 15w40
Ran 14hrs sunday nite
My brothers ope's
generic 22" push mower briggs 3.75spirit
out: previous owners (service pro sae30)
In: Quaker State Conventional 5w20
Ken
John Deere F510 mower Kawasaki motor
2 qts 5w30 Valvoline synthetic out
2 qts Mobil 1 0w40 in
PureOne filter
One season
