Post your latest small engine oil change
Honda GCV 160 on Troy-Bilt mower.
Out: Quaker State Ultimate Durability 10w30; with 5 hours break-in and lots of shiny metal flakes.
In: Ravenol TSJ 10w30
1986 Wheel Horse 210H
Out: Pennzoil conventional 30w
In: Pennzoil conventional 30w
1963 Lawn Bird Tiller
John Deere F510 mower with 14 hp Kawasaki power/trans unit, around 100 hours on the oil and filter.
Out 3.7L or Mobil 1 0w40 and Purolator 10241 filter
In 3.7 of Mobil 1 0w40 and a Fram PH3614
About 50 hours a year
Originally Posted By: greenaccord02
This can be a place to post our latest small engine oil change. I guess spring time would be the best time to start a thread like this.
I figure it would be good to include the engine info, brand and weight of oil, and filter where applicable. Here goes mine:
1954 B&S 2.5HP 6B-HS - 20oz. Mobil 1 15w40 Gold Cap
Troy-Bilt TB130XP with Honda 160 GCV engine: - 16oz Ravenol TSJ 10w30, ACEA A3/B4 every season. Going to start using Rotella T5 10w30 or T4 15w40 next season.
Winco WC10000VE Generator producing 10,500max/9,600cont. watts with VANGUARD 18-HP V-Twin Engine and Oil filter: 1.5 quarts of Chevron Delo 400 Severe Duty 15w30 CJ-4/SM, Baldwin B7165 Oil Filter every 50 hours if severe use or 100 hours normal use OCI
Scag 3 wheel zero turn rider (Grandfather's) - Kohler Command 18hp V-Twin
Out: Rotella T 15w40, Fram PH8170
In: Super Tech 15w40, Wix 57035
Lost power yesterday due to high winds. I did use my 10 year old 5KW Powermate and back feed through my welder outlet. Since it's been 3 years or so since I last did an OC I changed it out this morning. I use this generator to power a hedge trimmer and to trim trees with an electric chain saw, and to power the house when I lose grid power.
Engine: Subaru Robin
Out: Mobil 1 10w30
In: Mobil 1 10w30
1999 Craftsman GT5000 (with Kohler 20HP)
Out: Shell Rotella T5 10w30 and NAPA Gold filter
In: Chevron Delo 400 XLE SAE 10w30 and NAPA Gold filter
The Rotella looked and smelled great, but it was due on time.
I'm curious how the Delo will fare over the winter.
Self-propelled push Poulan Pro with Briggs & Stratton 625ex engine and 22" deck
Out: Castrol GTX synthetic blend 5w30 after about 7 hours
In: Castrol GTX synthetic blend 5w30
This is oil change number two on this mower. The fluid supplied by the mower manufacturer looked odd straight out of the container and only looked worse after I dumped it after 5 or so hr of use. Probably contained a lot of metal. This time oil was just dark which is fine. I hope I got all of the junk cleaned out. Who knows what kind of oil Poulan supplies with its equipment.
This is the last of the Autozone clearance GTX synblend purchased several years ago for $1/qt! Thank you, BITOG!
2005 John Deere LX 280 AWS. 18HP Kawasaki V-twin.
Out: JD Turf Gard 10w30 with a John Deere filter
In: 1qt Rotella T6 5w-40 and 3/4qt Formula Shell 10w30 with a Napa Gold 7145 filter
