Post your latest small engine oil change
Ingersol air compressor
5.0 HP Briggs
Out: Black mystery oil
In: Supertech 15/40
This compressor was given to me. The carb surges and needs work on the linkage. I will run some carb cleaner in the gas and see if that helps. If not I will tear down the carb and rebuild it. The engine doesn't burn oil. Right now it runs ok but I will give it some attention and see what i can do.
Generac pressure washer, Honda GX160 5.5 HP.
Out, not sure, likely Delo straight 30 weight.
In, VR-1 synthetic 20w50. Yep, it's thick, but at one point in the GX line, Honda had 20w50 in the temp chart. Overseas kart racers regularly use 15w50 as their "official" oil for the GX160. I'm not concerned, I don't think you can kill a Honda small engine with any oil choice.
Also replaced the carburetor with an Everest kit. The whole carb was about 16.00 on Amazon, and included the tank screen/fitting, fuel line, and gaskets. Nifty kit, about 30 minutes of work, fired up quickly and settled into an even idle. The old carb had something wrong, for the price, not worth troubleshooting. Engine would not start without ether, took forever, surged, and if ran out of fuel, the whole process was repeated.
My 20 year old John Deere GT275.
Out-John Deere Turf Guard 10W-30
In-Shell Rotella T-5 10W-30.
My 1973 John Deere 110
Out- SAE 30 Pennzoil.
In- Shell Rotella T-5 10W-30
Nothing runs and last like a Deere!
Husqvarna lawn tractor with 21hp Kohler Courage - Mobil 1 EP 10W/30 with STP filter
Craftsman lawn tractor with 25hp Briggs V-twin - Mobil 1 EP 10w/30 with an STP filter
Husqvarna 4wd self propelled push mower - Mobil 1 EP 10w/30
MTD cheapo push mower with Brigs Quantum 5hp - Mobil 1 EP 10w/30
4 Stoke edger and weed eater - Mobil 1 EP 10w/30
2012 Toro SR4 w/ Honda 160GCV Mower; Out - QSUD 10w30 / IN - QSUD 10w30
2014 Toro 721 QZR Snowblower; Out - QSUD 5w30. Will put in QSUD 5w30 in the Fall
2015 Dolmar MS 256.4 4 cycle Trimmer; Out - QSGB 10w30 / IN - QSGB 10w30 @ 3.4 OZ
2015 Husqvarna 327LDX with Honda GX25 Power Head; Out - QSGB 10w30 / IN - QSGB 10w30 @ ~3.5 oz
2015 Honda FG110 Tiller with Honda GX25; Out - QSGB 10w30 / IN QSGB 10w30 @ ~3.5 oZ
2013 Dolmar PB 251.4 4 cycle handheld blower; Out - QSUD 10w30 / IN QSUD 10w30
2013 Honda Eu2000i Generator; Out QSGB 5w30 / IN QSBG 10w30
Fresh 50:1 VP FUll Synthetic 2 Cycle mix for the 2smokes:
2010 Kawasaki KFTR27A Trimmer
2000 LawnBoy Duraforce 10547
2016 Husqvarna 525BX Handheld Blower
I bought a slightly used 4 stroke Craftsman trimmer. Not sure what oil was in it but when running it I got hear unstable high RPMs. Dumped it out and filled with Quaker State Ultimate Durability. Engine works really well now.
ETQ generator, 14 HP 1 cylinder OHV
Out: QS 30wt
In: 1 qt SL Havoline 30wt
Craftsman YTS 3000 42" rider, 21 HP 1 cylinder Briggs OHV
Out: QS Defy 10W-40, Havoline T-29 filter
In: 1 1/2 qts SF Amoco LDO 10W-40 conventional, Napa Gold 1348 filter
Only had to put air in one tire this year, boost one battery, and grease steering spindles on the riders.
Craftsman 19 HP B&S Platinum
B&S 5w30 synthetic out
10w30 Magnatec in. (AZ clearance oil)
FL910s off & B&S filter on ...
I bought my daughter a 195 CC walk behind "Yard Works" mower in 2012.
I didn't notice at the time it was one of those never change the oil models with no drain plug.
I expected the FF to look like black paint mixed with road kill, but it was surprisingly clear.
Why? Because for every hour of use it consumes about half of its oil capacity.
Nevertheless, I turned it upside down in a bucket and refilled it with 700ml of GTX 10W40 I found in her shed.
Husqvarna 54" garden tractor - Kohler Courage 24hp V-Twin (customer's)
-New head gasket, valve cover gasket, exhaust/intake gaskets (at only 200 hours)
-New battery
-New air filter, spark plugs
Out: black goo and a Kohler filter (looked original)
In: Rotella T 15w40, SuperTech ST3614 filter
2006 Hustler Z with a 23hp twin Kawasaki
Out: Rotella T6 5w40 with a Fram TG 4967
In: Same
OCI: 1 season which equals about 30-35 hours
580 hrs on the engine
Elderly couple who live down the street have a
2008 Great Dane - kawasaki 19hp with 1,190 hrs
Out: no idea and there wasn't a lot of it / kawasaki oil filter
In: Rotella T6 5w40 with a Fram TG 4967
Unk OCI
John Deere D140 lawn tractor. In and out:
Mobil 1 10w30 EP and Wix 51348 filter.
52 hours on the machine and 24 hours on the oil and filter. This seems like a waste, but the manual calls for a change every 12 months or 50 hours, whichever comes first.
