Post your latest small engine oil change
New to me..John Deere D100 lawn tractor..exact age unknown..guess about 2 years ..hour meter says 46 hours....briggs 17.5 hp engine
OUT...factory fill oil and oem short jd filter..
IN....oem long briggs filter(fram 3614 size) I had sitting around...Delo 400 LE 5w40 oil I had extra from daily driver truck.
Just purchased a Husqvarna gas pressure washer. Added the factory supplied oil yesterday. Ran for 5 hours and replaced per the manual. A few flecks drained out but overall looked pretty decent.
Edited to add: Briggs horizontal shaft engine. XR950 professional series.
Out: factory supplied 30wt
In: Pennzoil conventional 30wt
Wheelbarrow compressor Tecumseh 5hp flatty
Out: Super Tech 20w-50; 25-30hrs
In: WH 5w-20
1982 mtd 22" Briggs 3.5hp
Out: PM sae30
In: Edge TTo 5w-20
1988 lawnchief model20 Briggs 3hp
Out: Mobil 1 Extended Performance 0w20; 30hrs
In: peak 5w-20
Generac pressure washer Tecumseh endro195
Out: Mobil High Mileage 10w30; 40hrs
In: R3 15w40
Fresh utto in pump, drained every engine oci.
Much more this weekend.
Harvey
Craftsman LT 2500 (247.288841)
B&S 19.5 HP Single
Out - Rotella T6 5w-40 w/Motorcraft FL-910S
In - Same
Also replaced the spark plug with a NGK BKR5E
Craftsman YT4000 (917.289272)
B&S 24 HP Twin
Out: Rotella T6 5w-40 with Motorcraft FL-910s
In: Same
2011 Craftsman 42in. cut with a 21 HP briggs engine. OCI has been 1 1/2 year. Oil used was 0 on the dip stick.
Out: Mobil 1 10w30 and MC FL910s filter
In: Mobil 1 10w30 and a Super Tech filter.
The only reason I used the Super Tech is my local Walmart was out of the MC 910.
2005 John Deere G110 - 25hp Kohler Command V-Twin
In: Rotella T5 10w30
Out: Rotella T5 10w30
2008 Toro 22" Recycler mower - 190cc Briggs Flathead
In: 1/2 Rotella T5 10w30, 1/2 leftoverValvoline 5w30 conventional
Out: Rotella T6 5w40
1971 Gravely Super Convertible 7.6hp
In: Pennzoil High Mileage 10w30 w/ Napa Gold 1068
Out: Valvoline 10w30 w/ what I think is the original Wix 1068 filter (will be cutting soon)
Husquvarna YTH2348 Briggs 23HP V-Twin 144 hours.
Brought this back in service today. It was filthy and moldy.
It had been sitting over a year. and the oil had been in it over 2 years.
I drained all the gas out. Filled with fresh gas and replaced the fuel filter. Then I replaced the air filter.
I changed the oil. It had a mix of oils, I don't even remember what all was in it.
The filter was a Purolator L20195. FL400 size. It got the same one, which is old stock, probably '07 or '08.
Oil used is old 'M07' (2007) "Gold" German Castrol 0W30
Somehow the battery still had a charge and I was able to top it off with a 10 amp charger while I was working on it.
Had a little issue with the starter not wanting to push it through the compression, but that seems to have gone away. Maybe the battery just needed more charge.
And I just got finished hosing it down with a pressure washer. Next is to lube the grease points.
Jiffy propane ice auger
Out with the factory 0w-40
Filled with 6oz of Mobil 1 0w-40
Drained and filled followed by another drain and fill, factory oil was pretty sparkly which was to be expected. New oil is looking great after the season this year.
Toro Snowmaster (Loncin) 212cc engine - break-in
Refilled with Rotella T6 5W-40, and put away for safe keeping until next winter following storage instructions in the manual.
3 Craftsman YTS3000 42" cut riders, all with 21HP Briggs single cylinder OHV engines
Mower 1
Out: QS 20W-50, Pronto PO241 Filter
In: 1 1/2 Quarts QS Defy 10W-40, Havoline T-29 Filter
Mower 2
Out: 75/25 mix of Traveller's 20W-50 and SL Havoline HD 30
In: 1 1/2 Quarts QS Defy 10W-40, Left the Pronto PO241 filter in service
Mower 3
Out: QS 20W-50, Driveworks DW-241 filter
Mid 90's Murray 22" pusher, Single Cylinder Briggs engine
Out: Havoline 10W-40
In: 1 Quart QS Defy 10W-40
Toro Timecutter Z5000
21 HP Koehler engine
Out : Unknown oil from Toro shop service 2 years ago and Koehler Command oil filter (PH3614 size) from same shop service
In : 2 qts. Castrol Synblend 10w30 (pre-Magnatec) and Wix made Carquest Blue 85516 filter (PH3600 size)
Murray high wheel push mower 3-in-1 with B&S 625ex.
Out: Super Tech 5w30 full synthetic from last season. Mulched a ton of leaves at the end of the season, oil looked a tiny bit dirty.
In: Rotella T 15w40 poured a nice darkish amber color and smelled strange to me... Must be all those detergents.
