Post your latest small engine oil change
1990 Toro 5HP 21" Recycler Lawn Mower before Winter Storage
OUT: Mix of Mobil 1 Turbo Diesel Truck 5w-40 & Amsoil 4-Stroke Marine 10w-40
IN: Mix of Amsoil 4-Stroke Marine 10w-40 & Castrol Edge Ext. Performance 5w-30
Runs like a dream!!
1999 Simplicity lawn tractor with Kohler CV-14 engine.
Out: Rotella T5 10w-30 and Motorcraft FL-910S (1 year on oil, 2 years on filter).
In: Amsoil Formula 4-Stroke 10w-30/SAE 30 and Fram Ultra. My intended interval for this oil & filter is 2 seasons.
1992 5000 Watt Generac Mdl:PP5000 generator
Tecumseh HM100 159436P engine
Out: Amsoil Formula 4-Stroke 10W-30/SAE 30
In: Amsoil Formula 4-Stroke 10W-30/SAE 30
Change interval: Every 50 hours
Originally Posted By: Astro_Guy
Oversize filter for John Deere D140. What's not to like about a bigger filter at half the price?
And better quality! I cut open some of those expensive tiny filters and was not impressed. I now run the same Wix on my Deere.
Originally Posted By: Thebuckaman
8hp tecumseh snow king
Out-M1 5w30
In- GC 0w30 w/mos2
Hah, exact same engine, but I drained unknown oil and replaced with GC 0w30.
Just changed the generator today - Harbor Freight Chicago 5500w.
Out - 3 year old Pennzoil Ultra 5w30.
In - Pennzoil Synthetic Blend 5w30 (Gold bottle dexos1)
Finished up winterizing all of the machines over the last few weeks -
1990 Toro Wheel Horse 312-8 tractor with Kohler Magnum 12 engine - Rotella T6 5w40
Little Wonder push leaf blower with Subaru 9 hp engine - Napa syn. 5w30
Craftsman push mower with Honda GCV160 engine - Rotella T6 5w40
Craftsman LT2000,
Out - 1 quart NAPA full synthtic 5W-30 and 1 quart 10W-30, STP3600 filter...
In - 1 quart QSUD 5W-30 and 10W-30, DriveWorks DW-195 filter...
Normal fill is 56 ounces oil, with double oversized filter, 2 quarts exactly...
Regular filter is 2 inches long,
oversized filter is Fram 3614 (DW-241), 3 and a half inches, holds 4 more ounces oil...
double oversize is Fram 3600 (DW-195), just under 5 inches, holds 8 ounces more oil...
Filter sticks out like a giant hemmaroid...
DriveWorks filters on sale $1.85, at AAP, January 01, 2016...
Thanks mattwithcats, I will have to get some filters at AAP.
I have a triple oversize story.
The dls3500 has a intek plus 500cc 20hp.
The current fill is nextgen maxlife 5w-20 and ultra8A, yes 8A. Will get dumped in the late spring in 25hours.
Harvey
Lincoln Weldanpower w/16 hp Briggs flathead: Out, unknown. In, Napa 15w-40
Thermal Arc Predator w/Honda GX620: Out, mostly Napa 15w-40. In, Mobil 1 TDT 15w-40. Removed Honda 15400-PR3 filter, replaced with Napa 7356
Just buttoned up a Chonda GX200 clone that included ARC racing billet rod, aluminum flywheel with 5 degree timing advance, 18lb valve springs, cone filter, header, and governor removed.
It's on a pig of full suspension go kart. Don't have a tach, but I doubt I'm going over 4500 rpm before running out of straight away in the yard. Torque converter is fully upshifting now though which keeps the revs down as well. Definitely faster!!
Out: PYB 10w 30
In: Rotella synthetic 10w 30
Just changed oil in my Honda HRX217 mower, Mantis tiller w/Honda GX25 engine, and a Husqvarna 224L weed trimmer.
Out: PYB 10w30
In: PYB 10w30
Just bought a snow blower for my mower so I had to fire up the beast on straight 30 weight. It is a john Deere 318.
Out valvoline 30wt
In castrol blend 5w30 and Mobil one 5w30.
Craftsman G5500 garden tractor with 24hp Briggs and Stratton extended life series V-twin.
Out:
M1 EP 5w30 and OEM yellow filter.
In:
Napa synthetic 5w30 and OEM yellow filter.
68 hours total time, 40 hours on this oil change.
2004 Craftsman 26" blower 8hp Briggs PoweBuilt snow
Out: unknown brand syn 5w-20, 3yrs and many hours(60maybe)
In: M1 ep 0w-20 and mmo/mos2/RL
Don' t know why I fuss with winter oil, heated storage(50+degrees).
older blower w/ 8hp Tecumseh
Out: R6 0w-40 and mmo; might have 20hrs on it.
In: defy 5w-20 and mmo/RL
Honda em400
Out: m1 ep 0w-20; a little over 150hrs
In: . pup euro "sm" 5w-40
Craftsman hi-wheel trimmer 6.75hp tuhumpsy flatty
Out: fs 5w-20; 18hrs, no burning, flush fill(thick and black)
In: Mobil hm 10w-30
Harvey
gravely pro 148, 24 hp kaw.
out Shell RT 5 10/30 Napa gold filter
in Mobil 1 0/40 European Motorcraft 910s
Also change the blades from Gator G5s to G6s.
'90 John Deere 185 riding mower with 17hp Kawasaki single
Out: Delo 400LE 15W40 w/Purolator L14477
In: 1.5 qt Delo 400LE and .5 qt Rotella T 15W40 leftover from motorcycle OC w/Purolator L14477
