As I said above, I don’t believe it was dirty. I simply wanted to see if there’d be anything in the filter after a few OCIs. It wasn’t using oil, and there was nothing obvious under the valve cover. When I saw nothing in the filter pleats after 12k, I decided to go with a cheaper oil and use the VRP in the wife’s 2AR-FXE.
@edyvw have you considered muzzling that Honda engine? You may be approaching the mileage where the problems appear. I've muzzled 2 Odysseys. Good luck!
