You burn any oil on that setup?2013 Toyota Venza 3.5 V6
228,xxx miles
6 quarts SuperTech Synthetic 10W30, Mobil 1 M1C-251A filter
Drain plug 30 ft lbs
Oil filter 18 ft lbs
228,xxx miles
That's a pretty short run on a really nice oil.Here’s my spring oil change for the Subaru. I have several quarts of Amsoil XL 10w30 I’m burning through from a cheap market place haul. I’m still using smaller filter too with slightly lower bypass psi Got 4 left to burn before going to proper size. 6 pack price on eBay to hard to pass up.
2021 Subaru Outback 2.5L
48.3k Miles
Oil 3.5k Miles
Out: Amsoil Extended Life 5w30/ Premium Guard PG4612EX
In: Amsoil Extended Life 10w30/ Premium Guard PG4612EX
View attachment 332844View attachment 332843
Zero oil burn. In fact I’d say oil level rises 2-3mm from fuel. Once my XL stash burns up next year it’s going over to Amsoil Signature 0w40. I can then probably do once a year 6-8k changes. Let’s see.That's a pretty short run on a really nice oil.
Do you burn any oil yet in the Subaru?
Nice ratchet.![]()
I spot that odyssey battery I've been debating buying one I got to replace my jeeps. Worth the money?Here’s my spring oil change for the Subaru. I have several quarts of Amsoil XL 10w30 I’m burning through from a cheap market place haul. I’m still using smaller filter too with slightly lower bypass psi Got 4 left to burn before going to proper size. 6 pack price on eBay to hard to pass up.
48.3k Miles
Oil 3.5k Miles
Only brand I’ll buy from now on. Make sure you only buy fromhttps://wcbatteries.com/ to ensure fresh battery and not NOS. Absolutely love the performance.I spot that odyssey battery I've been debating buying one I got to replace my jeeps. Worth the money?
Still using some, but it has slowed down significantly. Over 8000 mi. it has gone from about a qt. in 1200 miles to a qt. in 2000. That is a tight estimation. Hoping for better results to come.Are you burning any oil?
Does the Traverse have the weird plastic Allen key drain plug?2023 Chevy Traverse 3.6 v6 with 32,000 miles
Valvoline extended 5w40 6 qts
AC Delco PF63 oil filter. The filter is a pita to change. Ugh
Its my aunts car, no idea I just change the oil and send it on its way. She calls me every 5k when the light goes off, she stays on top of maintenance and puts 5k quickly, every 2 months.You burn any oil on that setup?
I think it'll continue to improve. That engine benefits from 5W-30 too, so nice job going up a grade.Still using some, but it has slowed down significantly. Over 8000 mi. it has gone from about a qt. in 1200 miles to a qt. in 2000. That is a tight estimation. Hoping for better results to come.
Nice ratchet...Here’s my spring oil change for the Subaru. I have several quarts of Amsoil XL 10w30 I’m burning through from a cheap market place haul. I’m still using smaller filter too with slightly lower bypass psi Got 4 left to burn before going to proper size. 6 pack price on eBay to hard to pass up.
48.3k Miles
Oil 3.5k Miles
I've got 2. Well, 3 but one is stilling on a shelf brand new. Got mine from Napa and used their 20% off to make it more palatable.I spot that odyssey battery I've been debating buying one I got to replace my jeeps. Worth the money?
I love that your fleet is made up of older vehicles. Can you tell me the mileage of each?2011 Chevrolet Silverado 1500
5.3 Vortec V8
Out: Super Tech HD 30, AcDelco PF48E filter
In: Mobil 1 ESP 0w30, AcDelco PF48E filter
2011 Toyota Tundra
5.7 V8
Out: unknown oil, unknown cartridge filter
In: Pennzoil Platinum High Mileage 0w20, Toyota cartridge filter
2010 Chevrolet Silverado 1500
4.3 Vortec V6
Out: unknown oil, Fram Tough Guard TG3980 filter
In: Super Tech 5k 10w30, AcDelco PF52E filter
2016 Chevrolet Silverado 1500
5.3 V8
Out: unknown oil, AcDelco PF63 filter
In: Pennzoil Platinum 0w20, AcDelco PF63 filter
Thanks! Once you try Koken it’s hard to go back.Nice ratchet...
