Post your latest oil change
My 2012 F150 3.7
292,865 miles
Trying to slow down the valve cover leak till I have time to replace it, may go OEM instead of aftermarket this time. Not much time to do repairs driving 9k a month
That’s a good plan. I’ve got an old v6 Tacoma that has leaky VC gaskets. Using high mileage oil has helped. If I might ask, what do you do to drive that many miles in a month?
2023 Corolla Cross Hybrid 31577 miles on vehicle
Driven to jobsite 60 miles each way 5-6 days a week. Some days I take it easy and drive 65 some days traffic is bad and slow, some days I drive 80+. Average mpg this OCI was 43.7 . It only took two months and a week to accumulate these miles.
Miles last OCI 7057 . I normally go 10k do to the service type solidly warm temps. but this was first OCI with Valvoline restore and protect.
Out Valvoline restore and protect 0w20 with a fram premium oil filter. Not going to cut it open but it appeared very serviceable.
In 4.4 qts Valvoline restore and protect 0w20 with fram. Mid grade extra guard filter.
Nothing out of the ordinary. I will Probably run this OCI to 40k miles on vehicle to get back to round numbers. or about 8500 miles on oil.
2014 Chrysler Town and Country
133154 miles
2500ish on the oil
Out: Valvoline Restore and Protect 5w30 and a MOPAR Filter
In: 5 quarts Valvoline Restore and Protect and 1 quart Valvoline Max-Life, WIX filter.
The Short OCI is due to opening the top end up and changing out the rocker arms. I found some scuffing on the cams that made me concerned about metal in the oil.
The top end of this engine was very clean. I’m a 5000 mile OCI person, so it’s either that OCI or the Valvoline Restore and Protect. I’m extending the OCI from here on out as I plan on getting rid of the van soon. It has a reoccurring P0302 that I can’t seem to fix. It may be a worn cylinder.
133154 miles
2500ish on the oil
Looks good! How long have you been running Valvoline Restore and Protect for? I’m on my 2nd (or 3rd?) OCI of Valvoline Restore and Protect 5w30 on my 2012 Town & Country with around 183k on the clock
2008 Toyota Tundra 4WD Double Cab SR5 5.7L
Out: Pennzoil Platinum Euro L 5W30 SP & SuperTech MP10295 (3791 miles)
In: Rotella T6 5W30 Multi Vehicle SN (4 quarts) Rotella Gas Truck 5W30 SN (4 quarts)
Note: Had to use up my oldest stash. Rotella Gas Truck was from Advance Auto from multiple years back when it was 10 bucks for the 5 quart container.
2014 Isuzu D-Max 2WD Hi-Rider, 3.0L 4JJ1 diesel
210,000km service @ 207,290km (128,804 mi)
Out: unknown oil and oil filter (first change during my ownership)
In:
Nulon X-Pro 15w40 CK-4 mineral diesel oil
Donaldson P506082 oil filter
Nulon engine oil flush also used
Also used:
P903455 air filter
P505973 fuel filter
P903059 cabin air filter
~12,000km (7500 mi) / 10 months on old oil
This is the 39th oil change on the 2006 Honda Odyssey EX-L (VCM active) with 202K miles.
Out: Rotella Gas Truck 5w30
In: Rotella Gas Truck 5w30
Filter: 4th OCI on the Fram Ultra (original version with 20K rating)…filter only has about 14K miles on it.
OLM: 40% oil life remained. (~4500 miles since last oil change). Almost half that mileage was driving from MA to WI and back.
Engine is working fantastic. Only one part failed on this engine so far: an ignition coil. Timing belt replacement time is coming up very soon.
2022 Toyota Tundra w/3.4 I-Force. 3,838 miles on this OCI, 7,549 miles on the new engine, and 39,940 total vehicle miles.
Speediagnostix recommended 4k-5k miles for this run, but I'll be making a 1,500 mile round trip later this week so I had to either change a couple hundred miles early or a couple hundred miles late. Took a sample to mail off and see how break-in is trending.
Out: 7.7 qts Mobil 1 ESP 0W-30
Off: Toyota 90915-10010 filter
In: 7.7 qts Mobil 1 ESP 0W-30
On: Toyota 90915-10010 filter
I think it's a good idea that you're using a 30wt on that motor. I'm doing the same on mine. Where are you getting the 10010 filter? They've been superseded by the yzzn1(?) filter. I read that the 10010 is a better built filter. Looking forward to your UOA on it.
Nice, glad there are others out there running 30wt in their 3rd gens.
For the 10010 filter, I buy my mine from the local Toyota dealer where I purchased my truck. I've read a few times over the last year of people claiming these filters were superseded, but my dealer hadn't heard anything about it as of a couple months ago and was still ordering/receiving the 10010 filter for the Tundra. I bought (6) filters this last time just to stock up for a while. The 10010 do seem to be quality construction, made in Japan, orange silicone anti-drain back valve, and the pleats are always nice and straight. This last batch that I bought was more expensive, but still not bad I thought at $6.95/ea.
