What’s that filter you used? Thank You sir2013 Acura TL 3.5 V6, 193,300 miles
Out: Valvoline unknown, V0-106 filter (from Valvoline quick lube shop) 4200 miles on oil
In: Quaker State Full Synthetic High Mileage 0W-20, Denso 150-2006 filter
Went with QS as it is just a loaner car from a relative. My father is currently driving this after his ‘24 Camry was wrecked at the beginning of the year. Have had good results from this oil before. The old oil filter was way overtightened by some grease monkey, took me a while to get it off
Denso 150-2006 oil filter. Aftermarket Denso I got from summit I think.What’s that filter you used? Thank You sir
Are there two "crush washers" now they're recommending? One traditional metal one and your blue one above?‘23 Toyota Sienna Hybrid XLE
47,447 miles / 5,587 miles OCI / 3 months
Out/In: Valvoline Restore and Protect 0W-20 / 90915-YZZN1
3rd run of Valvoline Restore and Protect. Son did most of the work while I supported and supervised.
The same story continues with the Toyota OEM drain plug washers. The blue type also left material behind. It appears Valvoline Restore and Protect will take off the coating of both the black and blue type washers. No apparent leaks. However it’s something to be aware of as material can stick to the bolt and pan. Heat seems to be needed for this to happen as soaking them for a few months in a container caused no change. Put on a black washer again this time. I predict the same results as before. The Toyota oil filter gasket has not been affected at all.
I get Toyota oil filters from the local dealership and they provide the black ones with the purchase. Those appear more like soft plastic. However I also purchased some additional spares to have on hand just case which are blue fabric coated and metal. I’ve seen the dealership use both for oil changes.Are there two "crush washers" now they're recommending? One traditional metal one and your blue one above?
Very good sir. Thank You for thatDenso 150-2006 oil filter. Aftermarket Denso I got from summit I think.
