Post your latest oil change
1982 Chevrolet C30
350 small block V8
Out: Valvoline conventional 10w40, Schaeffer's Micron Moly EP, Napa Proselect 21060 filter
In: Swepco 306 15w40, AcDelco PF1218 filter
2015 Jeep Grand Cherokee
3.6 V6
Out: unknown oil, unknown cartridge filter
In: Mobil 1 ESP 0w30, Mopar cartridge filter
2018 Kia Soul +, 2.0l gdi (friend’s car)
98,579 on engine; P0014 code/check engine light
Out - unknown, miles on used oil unknown, stp oil filter. Oil level was 1qt to 1.5 qts low. Last dealer oil change at 89k, but possible later diy change between 89 and 98k.
In - Supertech Advanced 5w20, 4.25 qts. Kia oem blue oil filter xxxxx-35505, new Kia oem drain plug and gasket.
Fram Ultra 40k rated engine air filter. STP complete fuel system cleaner added week b4 oil change. Fresh breeze cabin air filter to be installed. Oem pcv to be installed.
Jeep WJ with 4.4k mile OCI
Out: Kirkland 5w-30 syn (probably) and an STP filter
In: 2 quarts Delvac 10w-30 and 4 quarts Kirkland 5w-30 plus a Microguard 51085 filter.
Not at my best today. I poured in 6 quarts of Delvac and then realized I hadn't put in the drain plug! 😭 I only had two quarts of Delvac left so she got a mix of two different oils.
Oops
I just came from under the wife’s 24 Altima.
Out came the fuel contaminated hpl that only had 7k on it and a fram ultra
In went torco sr1 and a purolator boss.
I hate to dump hpl so soon but this winter was brutal and she lets her car idle like a NYC cab driver. It was indeed nasty nasty!
Engine sounds much better.
Last week was my 18 rogue, same idling issues and short tripped like mad.
Out came Schaffer 9000 and a Bosch filter
In went Hps 5w20 and a pure one.
I started it up the other morning in the teens, half expecting a little rattle since it was 5w, it was quiet as a mouse.
Probably the new filter more than anything else.
