Post your latest oil change
My first crawl under as a kid. ;) First the oil got changed. Afterwards, I'm here checking the rear differential fluid
Is that the Swepco 502 Moly version?
If it is, it's $32 for a 16oz bottle at Amazon.
That Xado stuff is the most expensive I found..... around $64 for 12 ounces.
Yes, it's an organic moly that doesn't fall out of suspension. I get it considerably cheaper than that.
2010 Ford F-150
5.4 V8
Out: Schaeffer's 7000 5w20, Motorcraft FL820S filter
In: Swepco 306 Supreme Formula 10w30, Motorcraft FL820S filter
2015 Ram 1500
3.6 V6
Out: Mobil 1 5w20, Schaeffer's Micron Moly EP, Mopar cartridge filter
In: Amsoil Signature Series 5w20, Mopar cartridge filter
2022 Toyota Camry SE AWD 2.5
Out: HPL 5w30 NO VII and Fram Endurance FE 4967 filter (sample sent to blackstone)
In: HPL 0w30 premium plus and Fram Endurance FE 4967 filter
Changed rear diff and transfer case fluid as well to HPL 75w90 diff life
2024 Ram 2500 Laramie Mega Cab 6.7 Cummins
Out: Factory fill 3,037 miles/ 88 hours
In: 5w40 Valvoline Premium Blue Extreme and Fleetguard Stratapore LF16035 filter (sample sent to blackstone to get averages - next sample will go to oil analyzers or Cummins lab to better determine fuel dilution)
Changed rear diff factory fill and replaced with HPL 75W90 diff life as well
2008 Malibu 2.4L w/ 108k mi
OCI ~12mo 3k mi
Out - PPHM 5W30 & XG9018 cartridge
In- Same
I did some work with the replacing the VVT solenoid and the sensor on the exhaust bank lately, with the amount of sludge that was around the sensor, I think I may just switch to using whatever 0W or 5W I have excess of for the fall/winter and then in the spring/summer start using up my stash of 15W50, I know changing the oil every 6mo seems like a wast but this car gets driven like 3-4 times a day every day for short trips and we don't do enough highway driving to evap off all the condensation so I think going to a 6mo interval might be for the best. Filter came out looking good as always, I think when I do the 6mo oil change I'll just uncrew the cartridge housing let it drain off and then run the filter a second shorter OCI.
Today
2024 Kia Telluride
ST 5W30 syn STP S11934 filter
2017 Dodge 2500 6.7 Cummins
11 quarts Rotella 15W40, 1 quart Hot Shots Stiction Eliminator (owner wanted to use it)
Docs Diesel oil filter
2014 Chevy Traverse
ST 5W30 syn, Fram PH 10575
2005 Dodge 3500 5.9 Cummins
ST 15W40 Napa Proformer 27620 filter
2013 F250 6.7 Powerstroke
8 quarts ST15W40, 4 quarts O Reillys 15W40, 1 quart Rotella 15W40, STP S10890 filter
2001 Suburban 5.3 246K miles
Only at 2500 miles + 50 HOT temp idle hours or so since my last OCI and "change oil" light came on today
Out Pennzoil full syn ATV/UTV 10W-40
In Mix of Valvoline Daily protection white bottle/Castrol GTX 10W-40 dino oil/ STP ceramic oil treatment
Left the PS-2006 KN oil filter for this one last OCI
Going to run it until first week of November then its 10W-30 time !!
‘23 Toyota Sienna XLE Hybrid
22,765 miles / 5,250 miles OCI
Out: Toyota 0W16 (maybe) / YZZN1 Filter
In: Castrol Edge 0W20 / YZZN1 Filter
Not certain on the oil brand and viscosity. Just speculation cause the dealer invoice didn’t specify. Filter was OEM. Gumout was used on the previous tank. Next up for oil is VL R & P 0W20. Have a jug on hand and figure it will do some cleaning. Not that I think it needs it.
First oil change on the new (to us) ‘23 Sienna Hybrid after the ‘21 was totaled this summer. Picked it up certified used with low mileage. So far so good.
1999 Infiniti QX4, 258K, 5,200 OCI
A friend is a single Mom with 2 daughters getting ready for college soon. She works like 70 hours per week to keep the wheels on. A great gal...
Out: not even 3 qts Kirk 5w30, XG7310 (15K). Kinda funny, I tilt the vehicle to get a more complete drain...
In: 5 qts Kirk 5w30, TG7310
Other fluids looked good, set tires to 32 psi, buffed headlamps. I scolded her and told her to go stand in the corner until she understood what she did! The Costco sale helps out. All good.
Resurrecting a Mercury Marauder 4.6 L 32v DOHC w/ supercharger making 8.5# of boost. Car was not started for > 5 years.
Previously ran M1 or PP 5w30 and Napa Gold filters on 1 yr OCI's, usually with < 2,000 mi. per yr.
The garage put in 5w20 syn blend (Ford spec) and a bulk filter when they did the other work (fuel pump, fuel filter, tires, brakes etc etc).
I took that out today after 500 miles. It was pretty dark, but idk what it looked like when it went in. It definitely gave everything a good hot rinse.
Put in : 5 qt. vanilla M1 5w30 + 1 qt. HPL EC + Fram Endurance filter.
I plan to change over to HPL PCMO after this OCI.
Interesting adventures in oil lol !! I would defiantly run a good oil in that DOHC cobra engine. And choosing HPL is a smart move!!!
I'm a cheap ass lol So I'm going to run my 100qt stash of Pennzoil platinum 10W30 in my beater 09 with 200K miles and 8400 idle hours for my winter OCI's
From what I have read on the crown vic groups its best to keep the Motorcraft filter or Purolator one or Boss cause of the special ADBV
I have owned several Panther platform cars and I'm not aware of anything special about the MC ADBVs other than specifying silicone (?), which the Fram Endurance also has (?)
There is A LOT of fuss on the Ford boards about which end of the MC filter the bypass valve is located, but I'm not convinced that it actually matters, and I never even come close to the end of a filter's life expectancy.
For the low mileage of my OCI's, I am more interested in filtering efficiency than in long mileage capacity.
