Post your latest oil change
2000 328Ci, 140392 miles. Last oil change on 21May2023 at 135764 miles.
  1. Out: Mobil 1 Euro 0W-40 plus 300 cc LiquiMoly MoS2 and Hengst E106H D34 oil filter.
  2. In: Exactly the same as what came out.
2021 Subaru Crosstrek Sport, 38283 miles. Last oil change on 13Nov2023 at @32500 miles.
  1. Out: Pennzoil Ultra Platinum 5W-20 plus 300 mL LiquiMoly MoS2 and Mahle OC1177 filter.
  2. In: Castrol Edge Extended Performance 5W-20 plus 300 mL LiquiMoly MoS2 and Pennzoil HPZ-37 Platinum oil filter. I had been hoarding this filter since the 2015.
I’m curious… why were you hoarding this filter?
This was a left over filter (silver can) due to a couple of minor blemishes on the exterior. I had started using the Purolator Boss PBL14615, Fram XG6607 and also Mahle OC1177 filters on my 08 Impreza OBS and this Pennzoil branded filter was forgotten until I decided to use it this time.
Separately, I have an original Subaru filter from 1991 for a 1991 Legacy L+ AWD wagon still new in a box and also a couple of leftover blue Subaru filters (for an 08 Impreza OBS; not the defective ones) purchased @2009 - 2010 timeframe. Also have some leftover filters for an Expedition EB 5.4 from the from @2005 timeframe. Need to build a showcase of filters in the garage :).
2018 Ford F250 6.2L
Out Redline 5w30
In Quaker State 5w30
2024 Mazda CX-5 non-turbo 2.5.
6,315 miles on odometer. Second oil change for this car.
OCI - 4,000 miles
Out: Castrol Edge 0W-20, OEM Filter
In: Castrol Edge 0W-20, PG Filter.
Plan to change again at 10,000 miles and do 5K OCI from there on out. May switch to Quaker State also. $5 or so cheaper than the Castrol Edge. For 5K OCI, perfectly fine.
Did you drive around the neighborhood to get the miles perfect at 188K ????😳😳😳🤣🤣🤣🤣🤣
I live in the country, so if I drive around the neighborhood, it’s a 4.5 mile round trip around the closest block 🤣
I literally just pulled over on the way home… oil & transmission fluid was technically changed at 188002 but the round number seems cooler lol
2020 Kia Soul X-Line 2.0 MPI
27,500 Miles
3k OCI
Out
4.25 quarts Amsoil Euro 0w30
In
3.25 quarts Castrol Edge Euro 5w40
1 quart Castrol EDGE Extended Performance 5w20
Both my Royal Typewriter and Singer Sewing Machine under the hood are MIA. This engine is back to being mostly quiet.
Hoping things stays this way throughout the entire OCI.
‘21 Toyota Sienna
85K miles / 5K miles OCI
Out: Pennzoil Platinum 0W16 / 90915-YZZN1
In: Valvoline Restore and Protect 0W20 / 90915-YZZN1
Lookout! Another thickie convert! 🤣
Any specific issues that caused you to choose Valvoline Restore and Protect, or just as a preventative measure? And, did you get it on a sale/discount?
